SDC files -> when used?
amildm
Valued Contributor I
Hi All,
When SDC file used in the Quartus Compilation Flow?
As for my understanding, they are used:
- during the logic synthesis phase (timing/constraints-driven synthesis)
- during the logic cells placement/routing (?)
- during the Timing Sign-Off phase
Is that correct? Do the same SDC files are used during all the above phases?
Thank you!
sstrell
Yes, yes, yes, and yes.  Unless there's something in the file to have it not use a constraint (like an over constraint that should not be used during timing analysis), the same files are used throughout.
amildm
How is it possible to distinguish between the regular and over-constraints? Is there any argument, which should be used with the over-constraints, that tell the tool do not use it during the timing analysis?
ak6dn
Valued Contributor III
My Quartus designs typically have three files:
o DESIGN.qpf ... the Quartus Project File, which just sets the project revision
o DESIGN.qsf ... the Quartus Settings File, which has most of the Quartus "set_xxx ..." commands
     and
o DESIGN.sdc ... the Synopsys Design Constraints file, which has timing related commands like
                              create_clock, set_input_delay, set_false_path, etc
Each of the tools (quartus_map, quartus_fit, quartus_asm, quartus_sta, quartus_eda) have access to all
of the above files via the DESIGN.qpf/qsf/sdc file(s), so theoretically each tool can use any file contents
as it sees fit.
Nurina
Does the above reply answer your question?
Nurina
Nurina
We do not receive any response from you on the previous reply provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Nurina
amildm
I've tried to add comments to this case in the link, which you provided, but the 'Post' bottom is in grey (in the Timeline section), so I cannot add any comments there ... how to solve ?
Nurina
Have you tried refreshing the page? Can you post a screenshot of that? I will report this problem to internal team.
Nurina
amildm
Now it works... Posted my question there ....
Nurina
Why don't you want the overconstraints to be used during timing analysis? What do you what these to do, and/or which point of the compilation do you want it to be used?
Nurina
Nurina
Is this what you're looking for? It applies during fitter rather than timing analysis.
https://www.intel.com/content/www/us/en/docs/programmable/683243/21-3/using-fitter-overconstraints.html#pxe1487713499243__section_N10019_N10016_N10001
Nurina
Nurina
We do not receive any response from you on the previous answer provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Nurina
