17268 Discussions
lpm_add_sub synthesis error on Q2 9.0 SP2
Hi
I am using lpm_add_sub in ACEX1K EP1K50TC144-1 and I am getting this warning during synthesis process. I am using Q2 9.0 SP2 due to ACEX1K device support.
Warning: Ignored 6 CARRY_SUM primitives -- cannot place fan-in logic in single logic cell
Warning: Can't place logic feeding CARRY_SUM primitive "abs3:$00041|lpm_add_sub:$00002|addcore:adder1_0[0]|a_csnbuffer:result_node|cs_buffer[3]" in single logic cell
Warning: Node "abs3:$00041|lpm_abs:$00000|lcarry[12]" of type CARRY_SUM
Warning: Node "abs3:$00041|lpm_add_sub:$00002|addcore:adder1_0[0]|a_csnbuffer:result_node|cs_buffer[2]" of type CARRY_SUM
Basically the lpm_add_sub was not successfully implemented in the design and the functional simulation fails as well.
I can get rid of this warning by ticking the "ignore carry buffer" in the synthesis option but the fmax seems to suffers.
Ahdl code calling lpm_add_sub as below
(abs_diff[], , /over_max) = lpm_add_sub ( , abs_in[], limit[],gnd,h1,, )
WITH (LPM_WIDTH = 14, LPM_PIPELINE=2, LPM_REPRESENTATION="unsigned");
anybody know why I have to enable "ignore carry buffer" to get this to work? it seems strange for altera's lpm function to have this issue
Alan
Any feedback from Altera expert / guru is really appreciated
On Flex 10k devices I sometimes had problems where Quartus would refuse to compile for something that was "illegal in the device" but Max Plus2 didnt have a problem. Have you tried older versions of quartus or max plus 2?
As Acex is such an old part, and there are very few people that actually use AHDL any more (altera recommend you dont use it) you may struggle to get much help on the forum. Have you tried contacting altera mysupport?
Thanks Tricky , the code compile clean on Max+ II. It seems it is related to Quartus implementaion of lpm_add_sub instead of AHDL specific issue.
I've filed this issue with my_support , lets hope they will be able to give some explanation.
