17256 Discussions
mapping SPI HPS Periphera over HPS.
PShar32
I am using cyclone V, DE1 SOC (quartus lite 19.1), I am following this tutorial.  I made changes to .qsys file of GHRD which i get from here  for routing SPI over FPGA, every thing is good (no connection error, 0 error 0 warning)   but when i try to generate .hdl it stops with some error.
i just want to do SPI communication using python in HPS running linux.
log
Warning: hps_0.f2h_irq0: Cannot connect clock for irq_mapper.sender
Warning: hps_0.f2h_irq0: Cannot connect reset for irq_mapper.sender
Warning: hps_0.f2h_irq1: Cannot connect clock for irq_mapper_001.sender
Warning: hps_0.f2h_irq1: Cannot connect reset for irq_mapper_001.sender
Info: button_pio: Starting RTL generation for module 'soc_system_button_pio'
Info: button_pio: Generation command is [exec /home/pratik/intelFPGA_lite/19.1/quartus/linux64/perl/bin/perl -I /home/pratik/intelFPGA_lite/19.1/quartus/sopc_builder/bin/europa -I /home/pratik/intelFPGA_lite/19.1/quartus/sopc_builder/bin -I /home/pratik/intelFPGA_lite/19.1/quartus/../ip/altera/sopc_builder_ip/common -I /home/pratik/intelFPGA_lite/19.1/quartus/../ip/altera/sopc_builder_ip/altera_avalon_pio -- /home/pratik/intelFPGA_lite/19.1/quartus/../ip/altera/sopc_builder_ip/altera_avalon_pio/generate_rtl.pl --name=soc_system_button_pio --dir=/tmp/alt8625_3109179678941513487.dir/0002_button_pio_gen/ --quartus_dir=/home/pratik/intelFPGA_lite/19.1/quartus --verilog --config=/tmp/alt8625_3109179678941513487.dir/0002_button_pio_gen//soc_system_button_pio_component_configuration.pl --do_build_sim=0 ]
Info: button_pio: Can't locate Getopt/Long.pm in @INC (you may need to install the Getopt::Long module) (@INC contains: /home/pratik/intelFPGA_lite/19.1/quartus/sopc_builder/bin/europa /home/pratik/intelFPGA_lite/19.1/quartus/sopc_builder/bin /home/pratik/intelFPGA_lite/19.1/quartus/../ip/altera/sopc_builder_ip/common /home/pratik/intelFPGA_lite/19.1/quartus/../ip/altera/sopc_builder_ip/altera_avalon_pio /tools/perl/5.28.1/linux64/lib/site_perl/5.28.1/x86_64-linux /tools/perl/5.28.1/linux64/lib/site_perl/5.28.1 /tools/perl/5.28.1/linux64/lib/5.28.1/x86_64-linux /tools/perl/5.28.1/linux64/lib/5.28.1) at /home/pratik/intelFPGA_lite/19.1/quartus/../ip/altera/sopc_builder_ip/altera_avalon_pio/generate_rtl.pl line 18.
Info: button_pio: BEGIN failed--compilation aborted at /home/pratik/intelFPGA_lite/19.1/quartus/../ip/altera/sopc_builder_ip/altera_avalon_pio/generate_rtl.pl line 18.
Info: button_pio: Done RTL generation for module 'soc_system_button_pio'
Error: button_pio: Failed to find module soc_system_button_pio
Info: button_pio: "soc_system" instantiated altera_avalon_pio "button_pio"
Error: Generation stopped, 18 or more modules remaining
Info: soc_system: Done "soc_system" with 17 modules, 1 files
Error: qsys-generate failed with exit code 1: 2 Errors, 4 Warnings
Info: Finished: Create HDL design files for synthesis
PShar32
EBERLAZARE_I_Intel
Are you still facing this issue?
Have you check if your directory of your Quartus design files is in the right directory?
After downloading the GSRD, I recommend that you have your files inside the GSRD directory(Quartus design files).
PShar32
Thankyou for your help.. i am able to solve my problem..
