Hi, when I try to compile my testbench, on Quartus Prime, it gives an error message saying; Top partition does not contain any logic (error 12061). Is there anything that I could try to get rid of the error?
It's hard to know without seeing your design but as noted here:
does your file name match your entity name?
You could refer to this case which is similar to your case. Hope it helps.
Thanks for providing me with the above link @RichardTanSY_Altera ! It helped me figure it out!
I hope my last note contain the information needed. Since we do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Hi @RichardTanSY_Altera , thank you so much for your reply. The link you provided me with really helped. Thanks! and sorry for the late reply!
