17268 Discussions
modelsim testbench problem
I'm trying to simulate a system. Please find the attachement for the code.
Running the RTL simulation, I can't see in Modelsim the "i2c_slave_device" component.
Where am I wrong?
PS: I wrote the "i2c_slave_device" only for simulation purpose and it is not part of the "Channel_MNG" project.
Thanks for your help.
what do you mean by see in Modelsim? You need to be more specific.
Gruß Tobi
--- Quote Start ---
Gruß Tobi
--- Quote End ---
I mean that in the modelsim "sim" window, there is only the "UUT" component (Channel_MNG) but not the "uut1" (i2c_slave_device) component. It seems like I did the connection wrong in the testbench file.
how do you compile themfiles? If you don't specify a path, Modelsim does not know it needs to compile that file, and so it doen't exist.
--- Quote Start ---
--- Quote End ---
If I compile the file from Modelsim everything is fine. While I try to launch the simulation from Quartus the component does not apper in Modelsim.
You see it compiling in the transcript?
