I'm trying to simulate a system. Please find the attachement for the code. Running the RTL simulation, I can't see in Modelsim the "i2c_slave_device" component. Where am I wrong? PS: I wrote the "i2c_slave_device" only for simulation purpose and it is not part of the "Channel_MNG" project. Thanks for your help.Link Copied
what do you mean by see in Modelsim? You need to be more specific. Gruß Tobi- Mark as New
--- Quote Start --- Hi, what do you mean by see in Modelsim? You need to be more specific. Gruß Tobi --- Quote End --- I mean that in the modelsim "sim" window, there is only the "UUT" component (Channel_MNG) but not the "uut1" (i2c_slave_device) component. It seems like I did the connection wrong in the testbench file.
how do you compile themfiles? If you don't specify a path, Modelsim does not know it needs to compile that file, and so it doen't exist.
--- Quote Start --- how do you compile themfiles? If you don't specify a path, Modelsim does not know it needs to compile that file, and so it doen't exist. --- Quote End --- If I compile the file from Modelsim everything is fine. While I try to launch the simulation from Quartus the component does not apper in Modelsim.
You see it compiling in the transcript?
