17255 Discussions
output constant signal to oscilloscope
I need to generate a constant high signal to output to an oscilloscope.
I tried letting the an signal pulse_out <='1' and this didn't work either. I believe due to my knowledge that an output port signal needs to be driven by a clock.
I also tried using combinational logic and letting a two signals that were opposite of each other make a new signal by using AND,OR and this did not work either.
I feel like this is alot simpler than I think it is but I've tried everything!!! Any sample code of showing how to output a constant high value of '1' would be great.
use assign statement: http://www.asic-world.com/verilog/synthesis3.html
this isn't clocked in an always block.
Thus:
assign output = 1'b1;
--- Quote Start ---
Thus:
--- Quote End ---
The op is asking for vhdl, not verilog.
To the op. Assigning something to'1' should work just fine. You don't need a clock. What board are you using. Are you sure its not a problem of where you are probing?
Is the pulse_out signal assigned to the correct device pin? I mean the one where your probe is connected.
Has the fpga properly configured?
Solved. The oscilloscope that was used to detect the signal had a broken port.
