17253 Discussions
packages for synthesis
Using Quartus 15.1
I am trying to define my own types for IO in my modules.
I have generated the package foo_pkg.sv as follows:
package FOO_BUSSES;
typedef struct packed{
logic rd_wrn;
logic [31:0] address;
logic [10:0] burstsize;
logic transaction_dv;
logic dout_dv;
logic [63:0] dout;
logic din_dv;
logic [63:0] din;
logic transaction_rd;
logic din_rd;
} foo64_intf_p ;
endpackage // FOO_BUSSES
Now that I have the package defined I want to call it into the module foo_top.sv
module foo_top
import FOO_BUSSES::*;
# (parameter A = 1,
parameter B = 2)
( input CLK,
input RST,
foo64_intf_p FOODEF
endmodule
When I synthesize I get the following error
Error (10161): Verilog HDL error at foo_top.sv(nn): object "foo64_intf_p" is not declared
in my qip that calls these mods:
set_global_assignment -library "foo_flex" -name SYSTEMVERILOG_FILE [file join "../../ip_foo/foo_common/rtl/foo_pkg.sv"]
set_global_assignment -library "foo_flex" -name SYSTEMVERILOG_FILE [file join $::quartus(qip_path) "foo_top.sv"]
this code will simulate using various modelsim simulators.
any and all help will be appreciated.
Could you try by using 'input' keyword before 'foo64_intf_p FOODEF'?
Bhaumik
