problem with vga
back here again with a problem and I hope you can help me as I said to the vga not want to send the colors on the screen active only vh_sync
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
ENTITY VGA IS
PORT(
CLOCK_24: IN STD_LOGIC_VECTOR(1 downto 0);
VGA_HS,VGA_VS: OUT STD_LOGIC;
VGA_R,VGA_G,VGA_B: OUT STD_LOGIC_VECTOR(3 downto 0);
KEY: IN STD_LOGIC_VECTOR(3 downto 0);
SW : IN STD_LOGIC_VECTOR(1 downto 0)
END VGA;
ARCHITECTURE MAIN OF VGA IS
SIGNAL VGACLK,RESET: STD_LOGIC:='0';
component PLL is
port (
clk_in_clk : in std_logic := 'X'; -- clk
reset_reset : in std_logic := 'X'; -- reset
clk_out_clk : out std_logic -- clk
end component PLL;
COMPONENT SYNC IS
PORT(
CLK: IN STD_LOGIC;
HSYNC,VSYNC: OUT STD_LOGIC;
R,G,B : OUT STD_LOGIC_VECTOR(3 downto 0);
KEYS: IN STD_LOGIC_VECTOR(3 downto 0);
S: IN STD_LOGIC_VECTOR(1 downto 0)
END COMPONENT SYNC;
BEGIN
C1: SYNC PORT MAP(VGACLK,VGA_HS,VGA_VS,VGA_R,VGA_G,VGA_B,KEY,SW);
C2: PLL PORT MAP(CLOCK_24(0),RESET,VGACLK);
END MAIN;
library ieee;
use work.my.all;
ENTITY SYNC IS
PORT(
CLK: IN STD_LOGIC;
END SYNC;
ARCHITECTURE MAIN OF SYNC IS
SIGNAL RGB: STD_LOGIC_VECTOR(3 downto 0);
SIGNAL DRAW,DRAW2: STD_LOGIC;
SIGNAL SQ_X1,SQ_Y1: INTEGER RANGE 0 TO 1712:=200;
SIGNAL SQ_X2,SQ_Y2: INTEGER RANGE 0 TO 1712:=400;
SIGNAL HPOS: INTEGER RANGE 0 TO 1712:=0;
SIGNAL VPOS: INTEGER RANGE 0 TO 994:=0;
BEGIN
SQ(HPOS,VPOS,SQ_X1,SQ_Y1,RGB,DRAW);
SQ(HPOS,VPOS,SQ_X2,SQ_Y2,RGB,DRAW2);
PROCESS(CLK)
BEGIN
IF(CLK'EVENT AND CLK='1')THEN
IF(DRAW='1')THEN
IF(S(0)='1')THEN
R<=(OTHERS=>'1');
G<=(OTHERS=>'0');
B<=(OTHERS=>'0');
ELSE
R<=(OTHERS=>'1');
G<=(OTHERS=>'1');
B<=(OTHERS=>'1');
END IF;
END IF;
IF(DRAW2='1')THEN
IF(S(1)='1')THEN
R<=(OTHERS=>'1');
G<=(OTHERS=>'0');
B<=(OTHERS=>'0');
ELSE
R<=(OTHERS=>'1');
G<=(OTHERS=>'1');
B<=(OTHERS=>'1');
END IF;
END IF;
IF(DRAW='0' AND DRAW2='0')THEN
R<=(OTHERS=>'1');
G<=(OTHERS=>'0');
B<=(OTHERS=>'0');
END IF;
IF(HPOS<1712)THEN
HPOS<=HPOS+1;
ELSE
HPOS<=0;
IF(VPOS<994)THEN
VPOS<=VPOS+1;
ELSE
IF(S(0)='1')THEN
IF(KEYS(0)='0')THEN
SQ_X1<=SQ_X1+5;
END IF;
IF(KEYS(1)='0')THEN
SQ_X1<=SQ_X1-5;
END IF;
IF(KEYS(2)='0')THEN
SQ_Y1<=SQ_Y1+5;
END IF;
IF(KEYS(3)='0')THEN
SQ_Y1<=SQ_Y1-5;
END IF;
END IF;
IF(S(1)='1')THEN
IF(KEYS(0)='0')THEN
SQ_X2<=SQ_X2+5;
END IF;
IF(KEYS(1)='0')THEN
SQ_X2<=SQ_X2-5;
END IF;
IF(KEYS(2)='0')THEN
SQ_Y2<=SQ_Y2+5;
END IF;
IF(KEYS(3)='0')THEN
SQ_Y2<=SQ_Y2-5;
END IF;
END IF;
VPOS<=0;
END IF;
END IF;
IF(HPOS>80 AND HPOS<216)THEN
HSYNC<='0';
ELSE
HSYNC<='1';
END IF;
IF(VPOS>1 AND VPOS<30)THEN
VSYNC<='0';
ELSE
VSYNC<='1';
END IF;
IF((HPOS>0 AND HPOS<432)OR(VPOS>0 AND VPOS<34))THEN
R<=(OTHERS=>'0');
G<=(OTHERS=>'1');
B<=(OTHERS=>'1');
END IF;
END IF;
END PROCESS;
END MAIN;
library ieee;
PACKAGE MY IS
PROCEDURE SQ(SIGNAL Xcur,Ycur,Xpos,Ypos: IN INTEGER;SIGNAL RGB:OUT STD_LOGIC_VECTOR(3 downto 0);SIGNAL DRAW: OUT STD_LOGIC);
END MY;
PACKAGE BODY MY IS
PROCEDURE SQ(SIGNAL Xcur,Ycur,Xpos,Ypos: IN INTEGER;SIGNAL RGB:OUT STD_LOGIC_VECTOR(3 downto 0);SIGNAL DRAW: OUT STD_LOGIC) IS
BEGIN
IF(Xcur>Xpos AND Xcur<(Xpos+200) AND Ycur>Ypos AND Ycur<(Ypos+200))THEN
RGB<="1111";
DRAW<='1';
END IF;
END SQ;
END MY;
I post a component. A vga sync generator for 640 x 480 resolution. Its inputs are:
clk
rst
ptick -- a clock enable, when your system clock is not 25MHz.
Its outputs are:
vsync -- registered
hsync -- registered
video_on -- place red, green and blue only when this is active.
I used in many design. It works.
ok tnks bertulus (http://www.alteraforum.com/forum/member.php?u=77731)
even so I've been struggling with image generator vga if it's not too much trouble but if you could provide me some code of a program vga something simple to start programming with vga.
I have been working with several code and different resolutions but until now I could not generate any screen color televisions and even I have come to use the projector to be able to adjust the resolution so and still have not asked generate
if you can put me here or send to my email
cristian_llo@hotmail.com
