Can there be a process inside another process ?
I want to put a process inside a for loop. so since the for loop cannot be written outside a process, i weanted to put the for loop also in one process. What can be the alternative solution for this ? my code: library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.numeric_std.all; entity ber is port ( clk : in std_logic ); end ber; architecture ar of ber is type data is array (0 to 11) of std_ulogic; signal d: data; -- give the input data bit by bit signal q:std_logic_vector(0 to 3):="0001"; --signal rxd_bit:std_logic_vector(0 to 3):="1010"; -- shd be received from the txr signal k:std_logic_vector(0 to 3):="0000"; signal j,t: std_ulogic:='0'; begin p1: process(j) variable count : integer := -1; begin for j in 0 to 3 loop p2: process(t) -----------> ERROR : Illegal sequential statements variable m: integer := 0; begin m:=m+1; exit when m=5; q<=(q(2)xor q(3)) &q(0)&q(1)&q(2); k<=q; for t in 0 to 3 loop if (k(t) /= d(t+(4*(j-1)))) then count := count+1; end if; end loop; end process p2; end loop ; end process p2; end ar;Link Copied
Woooh !
1) I think you can't make a process inside a process 2) rename the loop variable 'j' and 't' OR rename/delete your SIGNALS 'j' and 't' : to avoid confusion 3) Could you post your schema ? I bet you need a synchronous design, if so, employ
process(clk) -- or process(reset_n, clk) if you had a reset_n
if rising_edge (clk) then
k<=q;
-- something like that : nested loops
-- you must build finite loops because the FPGA have a finite number of logic elements AND synthesizer wouldn't want infinite structure.
count := count+1;
end if;
end loop;
end loop;
end if;
end process;
-- It could be written easier, maybe.
Processes are never ending loops, so it wouldnt make sense to make a never ending loop inside another never ending loop.
Why not just the code in the inner process in the outer process?- Mark as New
okk..The value of the signals will change only once the process ends. But i want the q and k value to change each timew it enters the j for loop..this is the code that needs to be modified so that k and q values are updated each time it enters the loop.
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.numeric_std.all; entity ber is port ( clk : in std_logic ); end ber; architecture ar of ber is type data is array (0 to 11) of std_ulogic; signal d: data; -- give the input data bit by bit signal q:std_logic_vector(0 to 3):="0001"; signal k:std_logic_vector(0 to 3):="0000"; signal t: std_logic:='0'; begin p2: process(clk) variable count : integer := -1; begin if rising_edge(clk) then for j in 0 to 2 loop q<=(q(2)xor q(3)) &q(0)&q(1)&q(2); -- LFSR k<=q; end if; for t in 0 to 3 loop if (k(t) /= d(t+(4*j))) then count := count+1; end if; end loop; end loop; end process p2; end ar;- Mark as New
Think about the logic you're trying to describe. Your j loop just does the same thing 3 times (it doesnt do anything different on each iteration) and the t loop adds between 0 and 4 to the count variable.
I think you need to start again. Before writing any code, draw the circuit you are trying to achieve on a peice of paper. VHDL is a description language, not a programming language. If you dont know the circuit, how do you expect to describe it?- Mark as New
the t loop works fine in comparing the bits in d array with the k value and count is incremented when they differ.
The j loop does the same work 3 times. yes.It is because the signal values change only at the end of the process.I want the q and k values to change every time it enters j loop. How do I do that? I am sorry , I am new to VHDL .- Mark as New
You need to start again and rethink. This is NOT how to write VHDL. VHDL is NOT a programming language. It describes hardware.
You should refer to a good VHDL textbook or VHDL tutorial.
What is the purpose/goal of your "design" ? If it is not confidential. A checksum control on received bits ?
What is the desired behaviour ? The comparison "(k(t) /= d(t+(4*(j-1))))" sounds wrong, because for example t=0 and j=0 it gives d(-4) which doesn't exist. I guess 'd' may be a buffer whose size should be 4* size of 't'. --- Quote Start --- VHDL is NOT a programming language. It describes hardware. --- Quote End ---- Mark as New
--- Quote Start --- What is the purpose/goal of your "design" ? If it is not confidential. A checksum control on received bits ? What is the desired behaviour ? The comparison "(k(t) /= d(t+(4*(j-1))))" sounds wrong, because for example t=0 and j=0 it gives d(-4) which doesn't exist. I guess 'd' may be a buffer whose size should be 4* size of 't'. --- Quote End --- the purpose is to design a BER Tester. And when t=0 and j=0 it will be d(0)
--- Quote Start --- the purpose is to design a BER Tester. And when t=0 and j=0 it will be d(0) --- Quote End --- sry yes. the code had glitches.
