17267 Discussions
process inside another process?
Can there be a process inside another process ?
I want to put a process inside a for loop. so since the for loop cannot be written outside a process, i weanted to put the for loop also in one process. What can be the alternative solution for this ?
my code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
entity ber is
port ( clk : in std_logic
end ber;
architecture ar of ber is
type data is array (0 to 11) of std_ulogic;
signal d: data; -- give the input data bit by bit
signal q:std_logic_vector(0 to 3):="0001";
--signal rxd_bit:std_logic_vector(0 to 3):="1010"; -- shd be received from the txr
signal k:std_logic_vector(0 to 3):="0000";
signal j,t: std_ulogic:='0';
begin
p1: process(j)
variable count : integer := -1;
begin
for j in 0 to 3 loop
p2: process(t) -----------> ERROR : Illegal sequential statements
variable m: integer := 0;
begin
m:=m+1;
exit when m=5;
q<=(q(2)xor q(3)) &q(0)&q(1)&q(2);
k<=q;
for t in 0 to 3 loop
if (k(t) /= d(t+(4*(j-1)))) then
count := count+1;
end if;
end loop;
end process p2;
end loop ;
end process p2;
end ar;
Woooh !
1) I think you can't make a process inside a process
2) rename the loop variable 'j' and 't' OR rename/delete your SIGNALS 'j' and 't' : to avoid confusion
3) Could you post your schema ?
I bet you need a synchronous design, if so, employ
process(clk) -- or process(reset_n, clk) if you had a reset_n if rising_edge (clk) then q<=(q(2)xor q(3)) &q(0)&q(1)&q(2); k<=q; -- something like that : nested loops -- you must build finite loops because the FPGA have a finite number of logic elements AND synthesizer wouldn't want infinite structure. for j in 0 to 3 loop for t in 0 to 3 loop if (k(t) /= d(t+(4*(j-1)))) then count := count+1; end if; end loop; end loop; end if; end process; -- It could be written easier, maybe.
Processes are never ending loops, so it wouldnt make sense to make a never ending loop inside another never ending loop.
Why not just the code in the inner process in the outer process?
okk..The value of the signals will change only once the process ends. But i want the q and k value to change each timew it enters the j for loop..this is the code that needs to be modified so that k and q values are updated each time it enters the loop.
library ieee;
entity ber is
end ber;
signal t: std_logic:='0';
begin
p2: process(clk)
begin
if rising_edge(clk) then
for j in 0 to 2 loop
q<=(q(2)xor q(3)) &q(0)&q(1)&q(2); -- LFSR
k<=q;
end if;
if (k(t) /= d(t+(4*j))) then
count := count+1;
end if;
end loop;
end loop;
end process p2;
end ar;
Think about the logic you're trying to describe. Your j loop just does the same thing 3 times (it doesnt do anything different on each iteration) and the t loop adds between 0 and 4 to the count variable.
I think you need to start again. Before writing any code, draw the circuit you are trying to achieve on a peice of paper. VHDL is a description language, not a programming language. If you dont know the circuit, how do you expect to describe it?
the t loop works fine in comparing the bits in d array with the k value and count is incremented when they differ.
The j loop does the same work 3 times. yes.It is because the signal values change only at the end of the process.I want the q and k values to change every time it enters j loop. How do I do that?
I am sorry , I am new to VHDL .
You need to start again and rethink. This is NOT how to write VHDL. VHDL is NOT a programming language. It describes hardware.
You should refer to a good VHDL textbook or VHDL tutorial.
What is the purpose/goal of your "design" ? If it is not confidential. A checksum control on received bits ?
What is the desired behaviour ?
The comparison "(k(t) /= d(t+(4*(j-1))))" sounds wrong, because for example t=0 and j=0 it gives d(-4) which doesn't exist.
I guess 'd' may be a buffer whose size should be 4* size of 't'.
--- Quote Start ---
--- Quote End ---
--- Quote Start ---
--- Quote End ---
the purpose is to design a BER Tester. And when t=0 and j=0 it will be d(0)
--- Quote Start ---
--- Quote End ---
sry yes. the code had glitches.
