17266 Discussions
quartus 2: can't determine definition of operator "*"
I've got this error for the following code:
library IEEE;
--use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_unsigned.ALL;
use IEEE.STD_LOGIC_TEXTIO.ALL;
use ieee.numeric_std.all;
--package image_array_2 is
-- type image_array is array(0 to 49, 0 to 49) of unsigned(7 downto 0);
--type image_derivadas is array(0 to 49, 0 to 49) of unsigned (8 downto 0);
--end package image_array_2;
use work.imagens.all;
entity hornteste is
Port (
clk : in bit;
imagem: in image_array;
imagemanterior: in image_array;
Ix: out image_derivadas;
Iy: out image_derivadas;
It: out image_derivadas
end hornteste;
architecture Behavioral of hornteste is
begin
process (clk)
begin
If (clk 'event and clk = '1') then
for x in imagem'range(1) loop
for y in imagem'range(2) loop
Ix(x,y) <= 1/4 * (imagemanterior(x,y+1) - imagemanterior(x,y) + imagemanterior (x+1,y+1) - imagemanterior(x+1,y) + imagem(x,y+1) - imagem(x,y)+imagem(x+1,y+1)-imagem(x,y+1));
Iy(x,y) <= 1/4*(imagemanterior(x+1,y) - imagemanterior(x,y) + imagemanterior(x+1,y+1) - imagemanterior(x,y+1) + imagem(x+1,y) - imagem(x,y) + imagem(x+1,y+1) -imagem(x,y+1));
It(x,y) <= 1/4 * (imagem(x,y) - imagemanterior(x,y) + imagem(x+1,y)- imagemanterior(x+1,y) +imagem(x,y+1)- imagemanterior(x,y+1) + imagem(x+1,y+1)- imagemanterior(x+1,y+1));
end loop;
end loop;
end if ;
end process;
end Behavioral;
I've used the unsigned type for the signals in opertation. what's wrong with it? thanks in advance.
I cant see the package that contains the image_derivadas type. Have you accidently used std_logic_arith instead of numeric_std?
Just to note - all the Ix, Iy and It outputs are going to be 0 because 1/4 = 0
--- Quote Start ---
--- Quote End ---
the package is defined in another file as folowing:
package imagens is
type image_derivadas is array(0 to 49, 0 to 49) of signed (8 downto 0);
type image_19bits is array (0 to 49, 0 to 49) of signed (18 downto 0);
end imagens;
I've already had that kind of problem with divisions. Which is the best way to do a division in vhdl?
thanks.
Remember that 1/4 = 0 because it is integer division, and the VHDL rules mean that division is completed before multiply unless you put expressions in brackets. This is just standard programming when it comes to integer division
So 1/4 * 100 = 0
100 / 4 = 25.
Just put the /4 after the multiply:
(imagemanterior(x,y+1) - imagemanterior(x,y) + imagemanterior (x+1,y+1) - imagemanterior(x+1,y) + imagem(x,y+1) - imagem(x,y)+imagem(x+1,y+1)-imagem(x,y+1)) /4
/4 is safe in this case as it is just a power of 2, which is really just a bit shift and free in terms of logic. If you need any non-power of 2 division, then you need to use the division IP core.
The problem is because you are mixing signed and unsigned. Make everything signed and it should work.
--- Quote Start ---
So 1/4 * 100 = 0
100 / 4 = 25.
--- Quote End ---
I've changed all to signed. I still get an error at definition of operator "-".
I get the feeling the problem you're having problems with code you havent posted here.
I have compiled your code in your original post without errors.
Please post the whole code.
--- Quote Start ---
--- Quote End ---
the main code used in the project is called hornschunk and it was written like this:
library IEEE;
use IEEE.STD_LOGIC_signed.ALL;
package imagens is
type image_array is array(0 to 49, 0 to 49) of signed(8 downto 0);
type image_derivadas is array(0 to 49, 0 to 49) of signed (9 downto 0);
end imagens;
--type image_array is array(0 to 49, 0 to 49) of unsigned(7 downto 0);
entity opticalflow is
Port ( clk_0 : in bit;
ukfinal : out image_19bits ;
vkfinal: out image_19bits
end opticalflow;
architecture Behavioral of opticalflow is
signal entrada, entradaanterior : image_array;
signal Ix_0,Iy_0,It_0, dividendo_0 : image_derivadas;
signal divisor_0, uk_0, vk_0: image_19bits;
signal mediau_0, mediav_0, uk2_0, vk2_0,uk3_0,vk3_0, mediau2_0,mediav2_0,dividendo2_0,dividendo3_0: image_19bits;
--signal uk_0,vk_0,uk_1,vk_1,divisor_0 : SIGNED (32499 downto 0) ;
component inicializacao port(
clk: in bit;
imagem: out image_array;
imagemanterior: out image_array
); end component;
--*component inicializacao port(
-- clk: in bit;
-- imagem: out SIGNED (19999 DOWNTO 0);
-- imagemanterior: out SIGNED (19999 DOWNTO 0)
-- ); end component;
component stage_1 port(
clk: in bit ;
imagem : in image_array;
Iy : out image_derivadas;
It : out image_derivadas
); end component;
--component stage_1 port(
-- clk: in bit ;
-- imagem: in SIGNED (19999 DOWNTO 0);
-- imagemanterior: in SIGNED (19999 DOWNTO 0);
-- Ix: out SIGNED (3 DOWNTO 0);
-- Iy : out SIGNED (3 DOwNTO 0);
-- It : out SIGNED (3 DOWNTO 0)
component stage_2
port(
clk: in bit;
Ix: in image_derivadas;
Iy: in image_derivadas;
It: in image_derivadas;
divisor: out image_19bits;
dividendo: out image_derivadas
--uk:out SIGNED (9999 DOWnTO 0);
--vk:out SIGNED (9999 DOWNto 0)
); end component;
component first_iteration
port(
clk : in bit;
divisor: in image_19bits;
dividendo: in image_derivadas;
--uk: in SIGNED (9999 DOWNTO 0);
--vk: in SIGNED (9999 DOWNTO 0);
uk1: out image_19bits;
vk1: out image_19bits
); end component;
component medias_1
port(
clk: in bit;
uk1: in image_19bits;
vk1: in image_19bits;
mediau: out image_19bits;
mediav: out image_19bits
); end component;
component second_stage_2
port(
clk: in bit;
mediau: in image_19bits;
mediav: in image_19bits;
dividendo2: out image_19bits
); end component;
component second_iteration
port(
clk: in bit;
dividendo2: in image_19bits;
uk2: out image_19bits;
vk2: out image_19bits
); end component;
component medias_2
port(
clk: in bit;
uk2: in image_19bits;
vk2: in image_19bits;
mediau2: out image_19bits;
mediav2: out image_19bits
); end component;
component third_stage_2
port(
clk: in bit;
mediau2: in image_19bits;
mediav2: in image_19bits;
dividendo3: out image_19bits
); end component;
component third_iteration
port(
clk: in bit;
dividendo3: in image_19bits;
uk3: out image_19bits;
vk3: out image_19bits
); end component;
begin
U1: inicializacao PORT MAP (
clk=> clk_0,
imagem=> entrada,
imagemanterior => entradaanterior
U2: stage_1 PORT MAP (
clk => clk_0,
imagem =>entrada,
imagemanterior => entradaanterior,
Ix=> Ix_0,
Iy=>IY_0,
It=>IT_0
U3: stage_2 PORT MAP (
clk => clk_0,
Ix =>Ix_0,
Iy =>Iy_0,
It => It_0,
divisor => divisor_0,
dividendo => dividendo_0
U4: first_iteration PORT MAP (
clk => clk_0,
dividendo => dividendo_0,
Ix => Ix_0,
Iy=> Iy_0,
uk1 => uk_0,
vk1 => vk_0
--uk1 => ukfinal,
--vk1 => vkfinal
U5: medias_1 PORT MAP(
clk => clk_0,
uk1 => uk_0,
vk1 => vk_0,
mediau => mediau_0,
mediav =>mediav_0
U6: second_stage_2 PORT MAP(
clk => clk_0,
Ix => Ix_0,
Iy => Iy_0,
It => It_0,
mediau => mediau_0,
mediav => mediav_0,
divdendo2 => dividendo2_0
U7: second_iteration PORT MAP(
clk => clk_0,
dividendo2 => dividendo2_0,
mediau => mediau_0,
mediav => mediav_0,
Ix => Ix_0,
Iy => Iy_0,
uk2 => uk2_0,
vk2 => vk2_0
U8: medias_2 PORT MAP(
clk => clk_0,
uk2 => uk2_0,
vk2 => vk2_0,
mediau2 => mediau2_0,
mediav2 =>mediav2_0
U9: second_stage_2 PORT MAP(
clk => clk_0,
Ix => Ix_0,
Iy => Iy_0,
It => It_0,
mediav2 => mediav2_0,
divdendo2 => dividendo3_0
U10: third_iteration PORT MAP(
clk => clk_0,
dividendo3 => dividendo3_0,
Ix => Ix_0,
Iy => Iy_0,
uk3 => uk3_0,
vk3 => vk3_0
end behavioral;
The problem with this code is nothing more than misnaming of signals
mediau2 should be mediau
divdendo2 should be dividendo2
Please review the errors and study your own code.
--- Quote Start ---
--- Quote End ---
thanks. but i still get an error at opertator "-" in the first code.
The problem you are having is not in the code in the first post - that code compiles fine (with some length missmatch warnings).
Please post the code you are working with now as it is clearly not the code in the first post.
--- Quote Start ---
--- Quote End ---
the code is this:
library IEEE;
--use ieee.numeric_std.all;
entity stage_1 is
Port (
clk : in bit;
end stage_1;
architecture Behavioral of stage_1 is
begin
process (clk)
begin
Ix(x,y) <= ((imagemanterior(x,y+1) - imagemanterior(x,y) + imagemanterior (x+1,y+1) - imagemanterior(x+1,y) + imagem(x,y+1) - imagem(x,y)+imagem(x+1,y+1)-imagem(x,y+1)))/4;
Iy(x,y) <= ((imagemanterior(x+1,y) - imagemanterior(x,y) + imagemanterior(x+1,y+1) - imagemanterior(x,y+1) + imagem(x+1,y) - imagem(x,y) + imagem(x+1,y+1) -imagem(x,y+1)))/4;
It(x,y) <= (imagem(x,y) - imagemanterior(x,y) + imagem(x+1,y)- imagemanterior(x+1,y) +imagem(x,y+1)- imagemanterior(x,y+1) + imagem(x+1,y+1)- imagemanterior(x+1,y+1))/4;
end loop;
end loop;
end if ;
end process;
end Behavioral;
and the main code called hornshunck is this:
library IEEE;
package imagens is
end imagens;
entity hornschunk is
end hornschunk;
architecture Behavioral of hornschunk is
clk: in bit;
); end component;
-- clk: in bit;
clk: in bit ;
); end component;
-- clk: in bit ;
component stage_2
port(
clk: in bit;
); end component;
port(
clk : in bit;
); end component;
component medias_1
port(
clk: in bit;
); end component;
port(
clk: in bit;
); end component;
port(
clk: in bit;
); end component;
component medias_2
port(
clk: in bit;
); end component;
port(
clk: in bit;
); end component;
port(
clk: in bit;
); end component;
begin
clk=> clk_0,
imagem=> entrada,
clk => clk_0,
imagem =>entrada,
Ix=> Ix_0,
Iy=>IY_0,
It=>IT_0
clk => clk_0,
Ix =>Ix_0,
Iy =>Iy_0,
It => It_0,
clk => clk_0,
Ix => Ix_0,
Iy=> Iy_0,
uk1 => uk_0,
vk1 => vk_0
--uk1 => ukfinal,
--vk1 => vkfinal
clk => clk_0,
uk1 => uk_0,
vk1 => vk_0,
mediau => mediau_0,
mediav =>mediav_0
clk => clk_0,
Ix => Ix_0,
Iy => Iy_0,
It => It_0,
mediau => mediau_0,
mediav => mediav_0,
clk => clk_0,
mediau => mediau_0,
mediav => mediav_0,
Ix => Ix_0,
Iy => Iy_0,
uk2 => uk2_0,
vk2 => vk2_0
clk => clk_0,
uk2 => uk2_0,
vk2 => vk2_0,
mediav2 =>mediav2_0
U9: third_stage_2 PORT MAP(
clk => clk_0,
Ix => Ix_0,
Iy => Iy_0,
It => It_0,
clk => clk_0,
Ix => Ix_0,
Iy => Iy_0,
uk3 => uk3_0,
vk3 => vk3_0
end behavioral;
You've commented out the numeric std package.
