17255 Discussions
report_skew command fails when integrated in the timing tcl script, runs normally when ran manually
maitreya_ranade
I am trying to fetch skew value with the following command:
report_skew
-from [get_keepers *en_fec_er*data_out*] -to [get_ports *mlvds_tx*] -npaths 1000 -detail path_only -panel_name {Report Skew} -multi_corner -file "BuildOutput/TimingReport_TX_skew_game.txt"
This command runs normally when ran manually and fails when integrated in the timing tcl script. Find the attched screenshots
sstrell
When you say you put the command in your "timing tcl script", what do you mean?  The main .sdc file for the project? Or a Tcl script you're pointing to in the Timing Analyzer settings?  Or somewhere else?
maitreya_ranade
Hello @sstrell ,
I am referring to the Tcl script you're pointing to in the Timing Analyzer settings. Apologies for the delay in response.
KennyTan_Altera
Can you attached your design.qar file and also your tcl scripts for investigation? What command that you use to run the tcl script as well.
maitreya_ranade
Hey @KennyTan_Altera , I am not sure I can share the qar file due to confidentiality reasons but let me check up with my team & get back to you.  Apologies for the delay in response.
KennyTan_Altera
Is there any update on the above?
KennyTan_Altera
maitreya_ranade
KennyTan_Altera
As we do not receive any response from you on the previous question that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
