17255 Discussions
report timing with Tcl in QuartusII 11.0
Hi:
I'm trying to report timing with Tcl in QuartusII, first I open a project and constraint the clock about 125MHz, after compile the project, I want to see the actual fmax, I use Tcl to report the timing, my Tcl commands is as follow:
load_report $project_name puts
But when I use the command "get_timing_analysis_summary_results",come an error "Error:ERROR: Can't find panel: Timing Analyzer||Timing Analyzer Summary. Specify an existing report panel name"
I konw in QuartusII 11.0, Classic Timing Analyzer is away, is this a reason?
Thanks!
Cant you see the Fmax in the compilation report?
Yes, the whole compile flow is OK!
The get_timing_analysis_summary_results can only be used with the Classic Timing Analyzer.
OK, thank you for reply , the problem is resolved.
The command in QuartusII 8.1 is OK
