17253 Discussions
schematic, bus explode, please
Hello friends,
I need to feed LPM_ADD_SUB module which is on 37 bits with only 21 bits and the rest tied to gnd (MSB's). The problem is I can't figure out how, since those 21 bits are from LPM_MULT and the bus name is result[21..0] and the input of LPM_ADD_SUB wants datab[36..0].
I know this is simple but I haven't found yet and keep me nervous :)
ok, still isn't working, I wrote a small verilog to concatenate buses like that
module conv21to37(in,out); input in; output out; assign out = {16'b0000000000000000,in}; endmodule
But Quartus keep telling me
Error: Port "datab[0]" does not exist in macrofunction "inst13"
Error: Port "datab[10]" does not exist in macrofunction "inst13"
Error: Port "datab[11]" does not exist in macrofunction "inst13"
Error: Port "datab[12]" does not exist in macrofunction "inst13"
Error: Port "datab[1]" does not exist in macrofunction "inst13"
Error: Port "datab[2]" does not exist in macrofunction "inst13"
Error: Port "datab[3]" does not exist in macrofunction "inst13"
Error: Port "datab[4]" does not exist in macrofunction "inst13"
Error: Port "datab[5]" does not exist in macrofunction "inst13"
Error: Port "datab[6]" does not exist in macrofunction "inst13"
Error: Port "datab[7]" does not exist in macrofunction "inst13"
Error: Port "datab[8]" does not exist in macrofunction "inst13"
Error: Port "datab[9]" does not exist in macrofunction "inst13"
The macrofunction "inst13" is a LPM_MULT which is output 21 bits that I want to send into LPM_ADD_SUB which has a 37 bit bus on datab[36..0]
Any idea?
--- Quote Start ---
Any idea?
--- Quote End ---
have a look to the small project.
Kind regards
GPK
pletz, thank you very much, it was my mistake.
the bus explode / combine worked like expected from schematic, but the error was generated by 2'nd LPM_MULT instance, on which I was used copy - paste instead of re-generate a new one with wizard.
thanks again for example,
