17267 Discussions
.sdc file: TimeQuest Timing Analyzer (quartus II)
Any good tutorial with examples to setup the .sdc file? Besides, is it possible to generate the Verilog files based on a schematic file (.bdf)?
U can search at www.altera.com, there are some document on the timing analysis, which should have note on the sdc.
Foe generate the verilog, after u compile the design using Quartus II, u can generate verilong netlist using netlist writer.
--- Quote Start ---
--- Quote End ---
timequest user guide (http://www.alterawiki.com/wiki/timequest_user_guide
--- Quote Start ---
--- Quote End ---
Yes. In Quartus II: File -> Create / Update -> Create HDL Design File from Current File...
Or you can use netlist as tancheeseng84[/b] (http://www.alteraforum.com/forum/member.php?u=73976)[/b] suggested.
