i'm a student and recently i work on quartus,
i created a multilplier foloating point and i change the time costrint; why varyng the costraint the resurces do not change? example: clk= 1 ns aluts=629 clk=10 ns aluts=629链接已复制
7 回复数
changing the time constraints wont change resource usage. Usually, it just checks that the fitted design can meet your specified timing. If it doesnt meet timing, you can make it try and refit.
To change the resource usage, you have to change the top level design.resources do not vary because sitetizzatore does not consider the file.sdc or because the costraint does not affect the number of aluts?
it seems strange that the project with a clk = 1GHz and a clk= 100 MHz, uses the same resources. I would like to understand.If you look, I suspect that the 1GHz spec failed to meet timing, as even the top FPGAs struggle to get past 300Mhz without serious considerations given to pipelining in the origional source code.
How do you expect the synthesisor to change your design based on timing specs?I made the same project on xilinx and the resurces vary.
changing the options of xilinx Synthesis and setting "optmize area" the number of LUTs used varies. why this difference? sorry for my english and thanks for attention
