tcl in system mem editor
s002wjh
is there a guide on how to use tcl to rd/wr to mem ?
i try something similar to this, but with my own device name under quartus Tcl console, but it output error "quartus_stp"
so i guess whats the proper way to run in-systme memory editor via tcl console or command line?
begin_memory_edit -hardware_name "USB-Blaster \[USB-0\]" -device_name "@1: EP1S25/_HARDCOPY_FPGA_PROTOTYPE (0x020030DD)"
write_content_to_memory -instance_index 0 -start_address 575 -word_count 2 -content "0000001011011100"
puts [read_content_from_memory -instance_index 0 -start_address 575 -word_count 2 ]
write_content_to_memory -instance_index 0 -start_address 575 -word_count 2 -content "E2F1" -content_in_hex
puts [read_content_from_memory -instance_index 0 -start_address 575 -word_count 2 -content_in_hex]
end_memory_edit
RichardTanSY_Altera
You may checkout the user guide here Intel Quartus Prime Pro Edition User Guide: Scripting
Look for these tcl commands in the attached image.
s002wjh
i try that didn't work.  actually the above code are example from altera, i just modify a bit for my dev board device.   does quartus tcl console accept command such as  begin_memory_edit ?  it always output quartus_stp error.
RichardTanSY_Altera
The error message indicate that you need to run the tcl script using the executable command:
quartus_stp
Usage:
quartus_stp [-h | --help [=<option|topic>] |v ]
quartus_stp <project name> [<option>]
quartus_stp -t <script file> [<script args>]
quartus_stp -s
quartus_stp --tcl_eval <tcl command>
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
RichardTanSY_Altera
If you type help in the tcl console, it will displays a complete list of available Intel® Quartus® Prime Tcl packages available in tcl console.
Unfortunately, you will found that the quartus_stp packages is not available in the tcl console so you can't use the insystem_memory_edit tcl script directly in tcl console. You may need to run it using command prompt.
Fyi, for best results, run shell commands and Intel® Quartus® Prime executables from a system command prompt outside of the Intel® Quartus® Prime software GUI.
Richard Tan
RichardTanSY_Altera
I believed that I have answered your question.
With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
