17258 Discussions
variable declared outside subprogram or process must be shared variable
variable set_10_external : STD_LOGIC;
declaration error, variable declared outside subprogram or process must be shared variable
already declared a variable, got error, isn't it shared variable
architecture syn of Transmit2 is variable set_10_external : STD_LOGIC; begin H1:tether2 port map ( set_10 => set_10_external, --: IN STD_LOGIC; ...
finally i use signal , passed
