Intel® QuickAssist Technology (Intel® QAT)
For questions and discussions related to Intel® QuickAssist Technology (Intel® QAT).
88 Discussions
Request for Confirmation on PCB Thickness of Intel QAT8960 Card
jungsoolim
I would like to confirm the PCB thickness of the Intel QAT8960 card.
While the standard PCB thickness for PCIe cards is generally known to be 1.6 mm, we have identified a thickness of approximately 1.7 mm based on 3D model data for the QAT8960. However, this specification is not clearly stated in the official datasheet.
Could you please confirm the exact PCB thickness of the QAT8960 card?
Thank you for your support.
Jungsoo Lim
Ronny_G_Intel
Hi Jungsoo,
Based on the documentation provided via IPS, the PCB thickness is 1.6 mm.
I will proceed to close this issue as the answer has been confirmed.
Ronny G
Ronny_G_Intel
Hi Jungsoo,
I shared the details through IPS case 00963009 - Request for Confirmation on PCB Thickness of Intel QAT8960 Card. Please confirm if you can access it and whether the information meets your requirements.
Ronny G
Ronny_G_Intel
Hi Jungsoo,
Ronny G
