Agilex 5 LPDDR4 8GB
JBayl
What's the lowest density Agilex 5 supports 8GB of LPDDR4?  I'd appreciate if someone can point me to the correct documentation that shows which device density supports 8GB.
Our project requires at least 2 HPS (quad preferred) and 8GB of memory.  The project will use Linux OS and has minimal FPGA logic requirement and also don't require any transceivers.
Jol
sstrell
Any Agilex 5 SoC would support this: https://www.intel.com/content/www/us/en/docs/programmable/817467/25-1/external-memory-interfaces-emif-ip-lpddr4.html
I notice the spec estimator doesn't even have an option for memory density, just 64 bit data bus support and number of chip selects: https://www.intel.com/content/www/us/en/support/programmable/support-resources/support-centers/emif-spec-estimator.html
Jeet14
Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
JBayl
Thank you!
