Iam currently using the Intel Agilex® 7 FPGA I-Series Transceiver-SoC Development Kit with the device number AGIB027R31B1E1V (DK-SI-AGI027FA).
The provided link is specifically for the I-Series board: AgilexSoCGSRDSIAGI027.
I would like guidance on creating the U-Boot process and debugging U-Boot using ARM DS for this particular kit.
Thanking You....!
You can refer the procedure given on rocketboard for your board AGIB027R31B1E1V (DK-SI-AGI027FA).
For debugging u-boot from Arm Eclipse, refer below link.
Tiwari
Hi Tiwari
Thank you for your reference.
we have alredy follwed the procedure in the link but during the make process it throws error as below.
“Image 'u-boot' is missing external blobs and is non-functional: blob-ext
/binman/u-boot/fit/images/atf/blob-ext (bl31.bin):
Missing blob
Some images are invalid”
Do you have any idea about the above issue.please reply ASAP.
It looks like files are not generated properly or workspace path is not correct.
Can you re-try the steps from the scratch?
Tiwari
Please let me know if you have any question on this?
Tiwari
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
