573 Discussions
Agilex - i series debugging issue
HPS
Hi Intel,
I am currently using the Intel Agilex 7 FPGA I-Series Transceiver-SoC Development Kit with the device number AGIB027R31B1E1V (DK-SI-AGI027FA) for initializing Emmc and Ethernet for data transferring to emmc storage through TFTP
We have used SPL part in U-boot source code for initializing the pheriperals,but while debugging the code it stopped in EL2h mode and it shows error as below
WARNING(CMD452-COR167):
! Breakpoint 1 has benn pended
! No complilation unit matching”/home/anbu/Agilex-I-series_boot/u-boot-socfpga/arch/arm/mach-socfpga/spl_agilex.c” was found
WARNING(CMD315):Target is not running
Thanks & regards
Anbu
Jeet14
Can you add these below in the Execute Debugger command in the Arm DS debug as config tab
interrupt
restore "u-boot-spl-dtb.bin" binary 0xFFE00000
loadfile "u-boot-spl"
core 1
set $PC = $ENTRYPOINT
core 2
core 3
core 0
thbreak board_boot_order
continue
wait
set spl_boot_list[0]=0
set $PC=$LR
restore "u-boot.itb" binary 0x2000000
continue
Tiwari
Jeet14
Please let me know if you have any question on this?
Tiwari
HPS
Still faceing the same issue.
Jeet14
Hi Anbu,
Can you please share the snapshot of the debug configurations used in ARM DS?
Tiwari
HPS
Please find the attached image for your reference and also i have mentioned the execute debugger commands below.
interrupt
restore "/home/anbu/Agilex-I-series_boot/u-boot-socfpga/spl/u-boot-spl-dtb.bin" binary 0xFFE00000
loadfile "/home/anbu/Agilex-I-series_boot/u-boot-socfpga/spl/u-boot-spl"
core 1
core 2
core 3
core 0
continue
wait
set $PC=$LR
restore "/home/anbu/Agilex-I-series_boot/u-boot-socfpga/u-boot.itb" binary 0x2000000
continue
