567 ディスカッション
Autobooting Custom Application on Agilex F-series Transceiver SOC Development Kit
raju1421
新規コントリビューター I
1,980件の閲覧回数
Dear Experts,
I am currently working on the Agilex F-series Transceiver SOC Development kit with EMMC as the booting device. I need guidance on how to autoboot a custom application after Linux boot-up.
Could you please provide me with the necessary steps to achieve this? Your valuable insights and support would be highly appreciated.
Thank you in advance for your help.
Raju Satrasala
ラベル(1)
0 件の賞賛
7 返答(返信)
mabdrahi
従業員
1,967件の閲覧回数
Hi Raju,
Before I begin my investigation, i have item below to clarify:-
1) Does autoboot mean startup application?
2) Can you share your <application.bb>
3) can you share your layers.bb?
Thank you.
raju1421
新規コントリビューター I
1,961件の閲覧回数
Hi @mabdrahi ,
Yes,After linux booting is completed,custom application should start executing.
Please find the attached bblayers.conf & test-app_1.0.0.bb files.
Thanks & Regards
Raju Satrasala
mabdrahi
従業員
1,925件の閲覧回数
Hi
you may try to create file test.service with content below
[Unit]
Description=raju test app run at startup
[Service]
ExecStart=/usr/bin/raps -H -f
[Install]
WantedBy=multi-user.target
---------------then change and add below in test-app_1.0.0.tbb --------------
inherit systemd
SYSTEMD_AUTO_ENABLE = "enable"
SYSTEMD_SERVICE_${PN} = "cpeng.service"
SRC_URI = "file://raju_apps.c"
SRC_URI += "file://test.service"
S = "${WORKDIR}"
FILES_${PN} += "${systemd_unitdir}/system/test.service"
do_install() {
    install -d ${D}${bindir}
    install -m 0755 raps ${D}${bindir}
    install -d ${D}/${systemd_unitdir}/system
    install -m 0644 ${WORKDIR}/test.service ${D}/${systemd_unitdir}/system
mabdrahi
従業員
1,891件の閲覧回数
Hi Raju,
Any progress at your end?
mabdrahi
従業員
1,852件の閲覧回数
Good day Raju,
If the solution work at your side, I will close the case.
raju1421
新規コントリビューター I
1,845件の閲覧回数
Hi @mabdrahi ,
Thanks for the response.
For autobooting the custom application,first autlogin should work.
In our case it is not working as expected,so need to complete the
autologin then will try the steps provided by you.
Thanks & Regards
Satrasala Raju
raju1421
新規コントリビューター I
1,763件の閲覧回数
Hi @mabdrahi ,
After the discussion with Intel Team,
I have find a way for autologin and autoboot and its working as expected.
Thanks for the valuable support.
Thanks & Regards
Satrasala Raju
返信
