公告
573 討論
Building Yocto for FPGA boot first config on Agilex 7
Mikhail_a
新手
3,311 檢視
Hello.
I work with Intel Agilex ® 7 FPGA I-Series Transceiver-SoC Development Kit and AGIB027R31B1E2VR0 device. I need to build rootfs image. I've tried a guide I'd found on rocketboards (https://www.rocketboards.org/foswiki/Documentation/AgilexSoCGSRDSIAGI027) and with this guide i was able to build an sd card image with my own fpga bitstream file. But this guide is for HPS boot first config and now I need to create SD image for FPGA boot first config.
I was able to create .jic file, write it to QSPI flash and get FPGA configured from it after power up. Now it is a bit unclear for me how to modify Yocto building flow to disable FPGA configuration from U-Boot SSBL. Do you have any information about this?
0 積分
10 回應
Jeet14
員工
3,264 檢視
I am not able to open the shared link, it is broken. please resend once again.
Tiwari
Mikhail_a
新手
3,253 檢視
Jeet14
員工
3,216 檢視
From uboot you can configure the fpga using the below command-
https://www.intel.com/content/www/us/en/docs/programmable/683389/21-4/configuring-the-fpga-fabric-from-u-boot.html
Unfortunately we don't have such command to disable or reset the fpga configuration from the uboot.
Jeetesh
Mikhail_a
新手
3,211 檢視
Hello Jeetesh
Thank you for the link you've sent. But the problem is that I need to disable booting FPGA on SSBL stage and I couldn't find where is it can be disabled in U-Boot while compiling sd card image with Yocto.
I could only find something that controls booting process in file:
gsrd_socfpga/meta-intel-fpga-refdes/recipes-kernel/linux/linux-socfpga-lts/fit_kernel_agilex_fm87.its
		fpga-4 {
			description = "FPGA bitstream for GHRD";
			data = /incbin/("./ghrd.core.rbf");
			type = "fpga";
			arch = "arm64";
			compression = "none";
			load = <0xA000000>;
			hash {
				algo = "crc32";
And during booting it can bee seen in a log
## Loading fpga from FIT Image at 02000000 ...
   Trying 'fpga-4' fpga subimage
     Description:  FPGA bitstream for GHRD
     Type:         FPGA Image
     Compression:  uncompressed
     Data Start:   0x0283c534
     Data Size:    3350528 Bytes = 3.2 MiB
     Load Address: 0x0a000000
     Hash algo:    crc32
     Hash value:   a4fe125a
   Verifying Hash Integrity ... crc32+ OK
   Loading fpga from 0x0283c534 to 0x0a000000
....Error sending bitstream!
FPGA image is corrupted or invalid
SCRIPT FAILED: continuing...
** Unable to read file / **
Failed to load '/'
Jeet14
員工
3,189 檢視
Are you looking for when board boots up from the SD card, it only runs the uboot and kernel and it should not load bitfile while booting?
Tiwari
Mikhail_a
新手
3,173 檢視
Hello!
Yes this is exactly what i'm looking for as at the moment of booting from SD card I already have the FPGA configured.
Jeet14
員工
3,114 檢視
Please follow the below link on Build SD Card Image-
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderAgilex7#Boot_from_SD_Card_Example
In this above link it guide us on sd card image creation with multiple files like- u-boot.itb, Image, socfpga_agilex_socdk.dtb, ghrd.core.rbf.
In you case while creating SD card image don't include the .rbf file. and when you board booted up at u-boot run the fpga load command to configure the bitfile.
Tiwari
Mikhail_a
新手
3,110 檢視
Hello Tiwari
Thank you for this link. I'm going to try it and see if it works for me.
Jeet14
員工
3,066 檢視
I believe your enquiry has been answered. With that, I now transition this thread to community support.
Thank you.
Tiwari
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Mikhail_a
新手
3,056 檢視
Yeap I managed to build Yocto with FPGA boot first config.
Thank you.
回覆
