573 Discussions
Building Yocto for FPGA boot first config on Agilex 7
Mikhail_a
Hello.
I work with Intel Agilex ® 7 FPGA I-Series Transceiver-SoC Development Kit and AGIB027R31B1E2VR0 device. I need to build rootfs image. I've tried a guide I'd found on rocketboards (https://www.rocketboards.org/foswiki/Documentation/AgilexSoCGSRDSIAGI027) and with this guide i was able to build an sd card image with my own fpga bitstream file. But this guide is for HPS boot first config and now I need to create SD image for FPGA boot first config.
I was able to create .jic file, write it to QSPI flash and get FPGA configured from it after power up. Now it is a bit unclear for me how to modify Yocto building flow to disable FPGA configuration from U-Boot SSBL. Do you have any information about this?
Jeet14
I am not able to open the shared link, it is broken. please resend once again.
Tiwari
Mikhail_a
Jeet14
From uboot you can configure the fpga using the below command-
https://www.intel.com/content/www/us/en/docs/programmable/683389/21-4/configuring-the-fpga-fabric-from-u-boot.html
Unfortunately we don't have such command to disable or reset the fpga configuration from the uboot.
Jeetesh
Mikhail_a
Hello Jeetesh
Thank you for the link you've sent. But the problem is that I need to disable booting FPGA on SSBL stage and I couldn't find where is it can be disabled in U-Boot while compiling sd card image with Yocto.
I could only find something that controls booting process in file:
gsrd_socfpga/meta-intel-fpga-refdes/recipes-kernel/linux/linux-socfpga-lts/fit_kernel_agilex_fm87.its
		fpga-4 {
			description = "FPGA bitstream for GHRD";
			data = /incbin/("./ghrd.core.rbf");
			type = "fpga";
			arch = "arm64";
			compression = "none";
			load = <0xA000000>;
			hash {
				algo = "crc32";
And during booting it can bee seen in a log
## Loading fpga from FIT Image at 02000000 ...
   Trying 'fpga-4' fpga subimage
     Description:  FPGA bitstream for GHRD
     Type:         FPGA Image
     Compression:  uncompressed
     Data Start:   0x0283c534
     Data Size:    3350528 Bytes = 3.2 MiB
     Load Address: 0x0a000000
     Hash algo:    crc32
     Hash value:   a4fe125a
   Verifying Hash Integrity ... crc32+ OK
   Loading fpga from 0x0283c534 to 0x0a000000
....Error sending bitstream!
FPGA image is corrupted or invalid
SCRIPT FAILED: continuing...
** Unable to read file / **
Failed to load '/'
Jeet14
Are you looking for when board boots up from the SD card, it only runs the uboot and kernel and it should not load bitfile while booting?
Tiwari
Mikhail_a
Hello!
Yes this is exactly what i'm looking for as at the moment of booting from SD card I already have the FPGA configured.
Jeet14
Please follow the below link on Build SD Card Image-
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderAgilex7#Boot_from_SD_Card_Example
In this above link it guide us on sd card image creation with multiple files like- u-boot.itb, Image, socfpga_agilex_socdk.dtb, ghrd.core.rbf.
In you case while creating SD card image don't include the .rbf file. and when you board booted up at u-boot run the fpga load command to configure the bitfile.
Tiwari
Mikhail_a
Hello Tiwari
Thank you for this link. I'm going to try it and see if it works for me.
Jeet14
I believe your enquiry has been answered. With that, I now transition this thread to community support.
Thank you.
Tiwari
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Mikhail_a
Yeap I managed to build Yocto with FPGA boot first config.
Thank you.
