573 Discussions
How to use LW HPS to FPGA Bridge in Arria10 HPS?
sunyeong
I am trying to implement some features using Bridge interface.(Lightweight HPS-to-FPGA)
The "bridge enable" command in u-boot didn't work properly.
So, I modified the device tree and I can see that the command was operating properly.
And then I wrote application to control led_pio to verify whether bridge is working properly. But, it's not working properly.
Can you give me a guide about using this bridge(LightWeight HPS to FPGA) feature?
(Chip/SoC: Arria10,  linux kernel version: 6.1.68)
I attached device tree and application that I modified or wrote.
(dt_bridge_feature_added.txt, user_space_application.c)
Jung
Jeet14
Please refer the below link for setting up the GHRD & GSRD for A10 SoC development kit. This link is having example for the gpio/pio and the Lightweight HPS-to-FPGA.
https://www.rocketboards.org/foswiki/Documentation/Arria10SoCGSRD
Also, refer the below link for the linux user space application to blink the LEDs.
https://github.com/altera-opensource/linux-refdesigns/blob/master/blink/blink.c
Let me know if have any questions on this?
Tiwari
sunyeong
Thank you for comment.
I would like to use lightweight HPS-FPGA features in HPS.
I have already checked the document (url) you mentioned. But I can't find an example.
I'm having trouble finding examples, so can you tell me where I can find examples related to usage of LightWeight-HPS-to-FPGA?
As I understand, the lightweight HPS-FPGA bridge is connected to led_pio.
So, I tried to turn on/off led_pio by controlling the LightWeight-HPS-to-FPGA bridge in HPS.
So I don't need the blink.c example.
I would appreciate it if you could tell me where I can find examples related to LightWeight-HPS-to-FPGA.
Jung
sunyeong
I understand that you commented.
The blink.c example accesses peripheral address(0xff200010) using gpio driver(via sysfs interface).
I had misunderstood this as a gpio function and not a bridge function.
But, It seems that below content in your document(url, GSRD) is wrong.
The led_pio address of the attached device tree(socfpga_arria10_ghrd.dtsi) in your document is 0x100000010.
But, If you try following this document, the address is 0xff200010.
HOWTOCreateADevicetreeForArria10SoC
Which one is correct?
Jung.
Tiwari
Jeet14
GPIO number you can get it with the boot log and the device tree gpio@<address>.
E.g. In the boot log you will see the below-
gpiochip_find_base: found new base at 480
gpio gpiochip0: (/soc/gpio@0xf9000270): added GPIO chardev (254:0)
gpio gpiochip0: registered GPIOs 480 to 511 on /soc/gpio@0xf9000270
In the device tree you will see the gpio@<address>
*.dts file is having the node--> gpio@0xf9000270 with 32 bit.
Tiwari
Jeet14
Let me know if you have any other query on this?
If no, then I will close this case by EOD but it will be open for forum community/users to reply.
Tiwari
sunyeong
Thank you for your comments.
I also want to know how to program FPGA.
Is there a way to update rbf files in Arria10 SoC system based on GSRD?
(ghrd_10as066n2.periph.rbf , ghrd_10as066n2.core.rbf)
If there is a related guide document, please send it to me.
(I'm using QSPI boot mode and Arria10 SoC Development Kit now.)
Jung.
Jeet14
Hi Sunyeong,
I hope your first issue has been answered.
For second query/issue, please open new forum case as it is recommended not to mix the different queries on same issue/query. Other Expert will help you on new case.
Tiwari
sunyeong
Okay, I'll open a new forum case.
Jung.
