Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Facing MAC_MISMATCH during unseal data
Yan__Yudao
We try to seal a private key in encalve for future use:
    sealed_len = sgx_calc_sealed_data_size(0,sizeof(priv_key));
    sgx_status_t ret_priKey = sgx_seal_data(0, NULL, sizeof(priv_key), (uint8_t*)&priv_key, sealed_len, &tmpbuf); // tmpbuf will send out the sealed data
In the future, we do unseal in encalve as following:
    uint32_t decLen = sgx_get_encrypt_txt_len(&fix_data->enc_ec256_private_key);   // fix_data contained sealed data
    uint8_t *priv_tmp = (uint8_t*)malloc(decLen);
    memset(&sealed_data_tmp, 0, sizeof(tmpbuf));
    memcpy(&sealed_data_tmp, &fix_data->enc_ec256_private_key, sizeof(tmpbuf));
    sgx_status_t retUnseal = sgx_unseal_data(&sealed_data_tmp, NULL, 0, priv_tmp, &decLen);
But it shows MAC_MISMATCH during the unsealing.
Can anyone help on this?
Scott_R_Intel
Hi Yudao.
You didn't show how tmpbuf nor sealed_data_tmp are allocated...  Are you sure they are large enough to hold the data?
Regards.
Scott
Tom__Jimmy
Hi,YuDao.Yan,  your problem is solve?
I also encountered this problem, ask how to solve it.
Tom__Jimmy
Hi,Have you solved this problem, I also encountered this problem, ask how to solve it.
