Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1550 Discussions
I want to know the sgx_ecc256_compute_shared_dhkey() which Elliptical Curve use?
peng__yao
Hi
I try to use Openssl to change key with SGX use ecdh
when use sgx_ecc256_compute_shared_dhkey() to generate share-key,
but  the share-key not correct.
so i want to know which Elliptical Curve used in SGX.
 or are there any mistakes?
Thanks a lot for anyone's help!
you_w_
New Contributor III
Hi peng:
Before we call " sgx_ecc256_compute_shared_dhkey()", we need to call "sgx_ecc256_open_context()", the ecc curve is set in this method, you can find
/* construct a curve p-256 */
EC_GROUP* ec_group = EC_GROUP_new_by_curve_name(NID_X9_62_prime256v1);
in that method.
you
Yan__Yudao
I find them in openssl code:
static const struct {
EC_CURVE_DATA h;
unsigned char data[20 + 32 * 6];
} _EC_X9_62_PRIME_256V1 = {
NID_X9_62_prime_field, 20, 32, 1
/* seed */
0xC4, 0x9D, 0x36, 0x08, 0x86, 0xE7, 0x04, 0x93, 0x6A, 0x66, 0x78, 0xE1,
0x13, 0x9D, 0x26, 0xB7, 0x81, 0x9F, 0x7E, 0x90,
/* p */
0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
/* a */
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC,
/* b */
0x5A, 0xC6, 0x35, 0xD8, 0xAA, 0x3A, 0x93, 0xE7, 0xB3, 0xEB, 0xBD, 0x55,
0x76, 0x98, 0x86, 0xBC, 0x65, 0x1D, 0x06, 0xB0, 0xCC, 0x53, 0xB0, 0xF6,
0x3B, 0xCE, 0x3C, 0x3E, 0x27, 0xD2, 0x60, 0x4B,
/* x */
0x6B, 0x17, 0xD1, 0xF2, 0xE1, 0x2C, 0x42, 0x47, 0xF8, 0xBC, 0xE6, 0xE5,
0x63, 0xA4, 0x40, 0xF2, 0x77, 0x03, 0x7D, 0x81, 0x2D, 0xEB, 0x33, 0xA0,
0xF4, 0xA1, 0x39, 0x45, 0xD8, 0x98, 0xC2, 0x96,
/* y */
0x4f, 0xe3, 0x42, 0xe2, 0xfe, 0x1a, 0x7f, 0x9b, 0x8e, 0xe7, 0xeb, 0x4a,
0x7c, 0x0f, 0x9e, 0x16, 0x2b, 0xce, 0x33, 0x57, 0x6b, 0x31, 0x5e, 0xce,
0xcb, 0xb6, 0x40, 0x68, 0x37, 0xbf, 0x51, 0xf5,
/* order */
0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xBC, 0xE6, 0xFA, 0xAD, 0xA7, 0x17, 0x9E, 0x84,
0xF3, 0xB9, 0xCA, 0xC2, 0xFC, 0x63, 0x25, 0x51
