Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Unable to load SGX Driver
yg1
After downloading the Intel SGX driver with no error, I'm getting the following message while checking the driver logs.
Also under /dev there is no sgx related device (like sgx_enclave or sgx_provision ), only isgx is available.
P.S. Referred docs
sgx_linux_x64_driver_1.41.bin : sgx_linux_x64_driver_1.41 bin source
DCAP Driver installtion: developer reference doc DCAP Driver Installation , GitHub installation steps
OS: Debian 11 bullseye
Kindly help on this.
Sahira_Intel
Can you please send the output of
sudo lsmod | grep sgx
Sincerely,
Sahira
