Intel® Tiber Developer Cloud
Help connecting to or getting started on Intel® Tiber Developer Cloud
272 Discussions
How can I use winSCP?
MauiX_123
I need to use winSCP, but i need server, user and password.
Where can I find them?
Sorry I'm a novice.
Dayang_Intel
Hi MauiX_123,
For your information, you have reached to Intel® Developer Cloud support community. Could you kindly provide more context or purpose of using WinSCP? Just to confirm, are you using WinSCP to transfer files on Intel® Developer Cloud?
We would greatly appreciate it if you could provide any screenshots.
Dayang
MauiX_123
Hi, thank you for reply.
I want to use winSCP to transfer files on Intel Developer Cloud, yes.
MauiX_123
@Dayang_Intel pls explain me how to connect to winSCP
Dayang_Intel
Hi MauiX_123,
To transfer your files to the Intel® Developer Cloud instance using the SCP command, you can follow these detailed steps:
1. Launch your instance through the SSH command on the command prompt. Use the following command structure:
ssh -L local_port:remote_destination:remote_port user@ssh_server
2. Open a new command prompt window to begin the file transfer.
3. Navigate to the specific path of the file that you intend to upload. For example :
cd C:\Users\user
4. Execute the file transfer process by using the following command:
scp -P 10022 "file" ubuntu@localhost:~
Please try these steps and let us know if you encounter any issues or have further questions.
Dayang
MauiX_123
I'm trying to connect to the server with winSCP, but I don't now how to do it.
Are tehre any commands to find the server name, the port and the user?
I want to use winSCP to transfer files, not commands. WinSCP is more easy.
MauiX_123
Thank you very much, I'll try it.
I have only one question: can't I use the program winSCP?
Dayang_Intel
Hi MauiX_123,
Thank you for your response. We are checking with the Engineering team regarding this issue and will update you as soon as possible. We apologize for the inconvenience caused.
Dayang
MauiX_123
MauiX_123
@Dayang_Intelwhere can I find my password?
thanks
MauiX_123
to have the access to winSCP
Nurul_Intel
Hi MauiX_123,
Thank you for your patience. Please follow this instruction to use WinSCP with a public key. For your information, the key needs to be converted to putty format to be able to establish the connection. Kindly give it a try and let us know if you require any further assistance.
Nurul
MauiX_123
Dayang_Intel
Hi MauiX_123,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Dayang
MauiX_123
i don't now what to do
MauiX_123
where can i find the host name? can i put the ip? @Nurul_Intel
Nurul_Intel
Hi MauiX_123,
The instance's IP address can be used as your host name. You may refer to your SSH command when you launch the instance. For example, the host name would be the IP address at the end of your SSH command: ssh -J guest@JUMP_HOST_IP ubuntu@HOST_NAME.
Nurul
MauiX_123
I tried with my private ppk key, my vps's IP as the hostname and with my user (u********). It doesn't work.
I'm trying tu use the devcloud vps since a month.
Dayang_Intel
Hi MauiX_123,
Could you please provide any relevant screenshot of the error you're encountering so we can assist you effectively?
Dayang
MauiX_123
@Dayang_Intel @Nurul_Intel I tryed with cyberduck, it doesn't work.
Tomorrow I will send you the winSCP scrennshots
Dayang_Intel
Hi MauiX_123,
This thread will no longer be monitored since we have provided information. If you need any additional information from Intel, please submit a new question.
Dayang
