- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
We would like to update the firmware and Create the Raid 0 VD using Seagate SAS HDD,
But we encounter something wrong:
1. Checking command shows abnormal state. It shows the disk abnormal state (UGUnsp)
by using storcli show all (storcli_show_all.jpg). And it will create failing.
2. Create Raid 0 by storcli add vd command fail.
3. updating the firmware fail by sg tool.
What does the abnormal state mean(UGUnsp)? These HDD are all healthy from Seagate . Please give the idea or help, thanks.
Note:
The detail storcli log in attachment. (Log_Hung.txt)
HDD type:
Seagate , SAS HDD
Br. harrison
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello User15873737757611979935,
Thank you for contacting Intel Customer Support.
Can you please provide us the model of your server board and also let us know if you have tried with a different hard drive?
Finally, please let us if you have tried to create a different RAID type and if so, if you get the same issue.
Sergio S.
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Sergio S. ,
Our server board is using Intel x86 CPU the attachment is the log of lscpu, lspci, lsusb (log_WBdevice.txt).
And we create the RAID0 RAID1 also failed(log_storcli64_raid0_raid1_created_fail.txt).
We have two batch of Seagate drives to be accessory for server production now;
the SAS_DISK_A(SAS_DISK_A.jpg) is working fine for our previous shipping, and the SAS_DISK_B(SAS_DISK_B.jpg) are our current usage, and they always show UGUnsp state,
And cannot to be created for RAID usage.
The these batch of drives are factory testing normal.
Note:
we also provide the PDLIST information using CmdTool2 .
br. harrison
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thank you for the additional information, please allow us more time to check on this issue.
Sergio S.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Please help us by providing the following information:
The Linux version that you are currently using.
Also, please provide us the StorCLI version you used to create the RAID volumes.
Additionally, we would like to recommend you to update the firmware of in the SAS expander card, you can find the latest version here:
https://downloadcenter.intel.com/download/27884/
We will be looking forward to your reply.
Sergio S.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Sergio,
- Linux version:
Distributor ID: RedHatEnterpriseServer
Description: Red Hat Enterprise Linux Server release 6.5 (Santiago)
Release: 6.5
2. SorCLI version:
[root@localhost ~]# /opt/MegaRAID/storcli/storcli64
Storage Command Line Tool Ver 007.0813.0000.0000 Dec 14, Cc2018
root@localhost ~]# /opt/MegaRAID/CmdTool2/CmdTool2 -Version -Cli -a0
MegaCLI SAS RAID Management Tool Ver 8.07.15 Feb 27, 2014
(c)Copyright 2014, LSI Corporation, All Rights Reserved.
3. Why not create raid through SAS expander ?
it's because the limitation of our hardware design (raid controller + end device),
BTW, does this type of raid controller support 4k sector SAS HDD ?
Are Advanced Format / 4K / 512e disk drives supported on LSI controllers?
==> it seems have the same condition with mine.
And i will also try to use other HBA card to do the RAID creation in our factory at the same time.
thanks
Harrison
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I am thinking about the same with the native 4k HDD support on this RMS3CC080 Raid controller. I am trying to find the information about that but still don't have it yet. I will continue researching this. Apparently, UGUnsp means Unconfigure Good Unsupported.
An alternate way to discard this option would be to try a 512 HDD and see if it does not show up as blocked under BIOS.
Something else you could try is to install the Intel RAID web console 3 RWC3 for RAID controller management and check the HDD status.
Will look forward for your updates.
Jose A.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
hi Jose A.,
thanks for your reply, and
- An alternate way to discard this option would be to try a 512 HDD and see if it does not show up as blocked under BIOS.
==> use 512 HDD will not show up as blocked under BIOS. But this is only for test , not for our shipping requirement.
i don't know is it a incompatible problem or something mismatch between Seagate 4kn HDD and Raid Module.
2. Intel RAID web console 3 RWC3
==> i am trying to downgrade and get the related package for our old RedHat 6.5 OS from factory. And will update the result soon.
BTW, i have try to use other LSI HBA Card (LSI 9460-16i), and have the same result. (Unconfigure good, not support) about 4kn SAS HDD(SAS_DISK_B) result.
Br. harrison
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thank you for letting us know those important details.
We are going to double-check some details from our end, and as soon as possible we will be getting back to you in order to proceed with the next step.
Emeth O.
Intel Server Specialist.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
We would like to inform you that hat your RAID controller and the expander are compatible with 4Kn drives. That shouldn't be a problem here.
You can find more information here:
Support for 4Kn and 512e Advanced Format Disks with Intel® RAID Controllers:
https://www.intel.com/content/www/us/en/support/articles/000024132/server-products.html
In addition to the above, the system should be set to UEFI boot mode, so we recommend you to so by following these steps:
1. Boot the computer and press the F2 key to start the BIOS setup utility during start.
2. When the initial window appears, select Setup Menu and press Enter.
3. From the Setup Menu, select Boot Maintenance Manager and press Enter.
4. From the Boot Maintenance Manager, select Advanced Boot Options and press Enter.
5. From the Advanced Boot Options menu, change Boot Mode to UEFI.
6. Save Changes and reboot by pressing the F10 key.
After following the previous steps the RAID configuration is not going to be done from a Ctrl + R screen but from within BIOS You can find more information here:
https://www.intel.com/content/www/us/en/support/articles/000006189/server-products.html
That could be the reason for the UGunsp state.
Please do not hesitate to contact us again if you need further assistance.
Sergio S.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
hi Sergio ,
thanks for your reply ,
We are checking the version of drive firmware which provide from our customer who working with Seagate US.
Because it is strange that two different part number of drive using the same firmware said by Seagate FAE.
And we will also do the way of UEFI boot you suggest.
thanks
harrison
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thank you for the update, please let us know on the outcome from the hard drive manufacturer and also on the UEFI boot suggestion.
I will follow up with you next Thursday.
Sergio S.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I am following your thread and would like to know if you were able to perform the recommendations provided earlier.
Thank you.
PS.
I will follow up with you on 6-1-20.
Sergio S.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I am following your thread and if you still need further assistance and if you were able to get the missing information.
Thank you.
Sergio S.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
We are following up on a case that is still open with the issue It can not create Raid 0 or update HDD firmware through Intel integrated RAID Module RMS3CC080 we know that this is important for you to get it resolved and it is also equally important for us to get you the right solution.
Sergio S.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
We are following your thread and we would like to know if you need further assistance or if we can close it.
Sergio S.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
We would like to inform you that we are going to close this thread for now.
Additionally, we would like to include the information that we provided you before from the previous post in regards to the support for 4Kn and 512e Advanced Format Disks with Intel® RAID Controllers:
Sergio S.
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
