5184 Discussions
S5520SC Board will not accept over 8GB memory. What to do?
RWats1
My S5520SC Intel Board will not accept over 8GB memory. What to do. Running XP 64 bit.
Also forum does not apperar to have an English Language option.
Bob AZ
WGaul
Is the RAM on Intel's list of compatible hardware or conversely found on the RAM manufacturer's list of suggested RAM?
Compatible hardware with Intel Workstation Board S5520SC is listed on a linked PDF following this link:
http://www.intel.com/support/motherboards/server/s5520sc/sb/CS-030228.htm Intel® Workstation Board S5520SC — Tested Memory and Hardware List
A company like Kingston would suggest the following, some of which can be found on Intel's tested list:
http://www.kingston.com/en/memory/search/Default.aspx?DeviceType=7&Mfr=INT&Line=S5520SC%20/%20S5520SCR&Model=54391&Description=Kingston_ValueRam_Memory_Server_Premier_Memory_Intel_Cerfified_Memory_for_INT_S5520SC_/_S5520SCR_Intel_-_S5520SC_/_S5520SCR_Workstation Kingston Server Premier for Intel S5520SC / S5520SCR Workstation
What RAM are you trying? I also have an S5520SC under my desk.
Kevin_M_Intel
Hello mailto:rwatson767@aol.com rwatson767@aol.com,
Let me help you with this.
Please note that you reached a different community for your product but I will move your question to the Server community.
Kevin M
WGaul
RWats1
Crucial CT25664BA1339 2GB 240 P/N DIMM 256MX64 DDR3.
Others have said that perhaps I need to update the BIOS and I have tried to do this to no avail.
Bob AZ
RWats1
My 8GB that is already installed is the Crucial type that I mentioned.
And this box for replying has some strange spelling/wording that makes it difficult.
My Email is mailto:rwatson767@aol.com rwatson767@aol.com.
Bob AZ
David_A_Intel
I checked the model of the memory you are using and it seems that these modules are Non-ECC modules, and that the modules are rated for Desktop systems.
Intel always recommends the use of validated hardware to avoid unforeseen issues.
