789 Обсуждение
Problems to compile std::views with oneapi compiler (version 2023.0.0) on linux
MXG
Новый участник I
2 102Просмотр.
We problems to compile std::views with oneapi compiler (version 2023.0.0) on Linux:
/opt/intel/oneapi/compiler/2023.0.0/linux/bin/icpx -std=c++20 test_view.cxx -o test_view
- it seems to work fine using the same version on Windows.
Attached is the code snippet and the build error log from Redhat 8
Morten Gaupaas
Code snippet:
#include <iostream>
#include <ranges>
using namespace std;
int main()
{ auto even = [](int i) { return 0 == i % 2; };
  auto square = [](int i) { return i * i; };
  for (int i : std::views::iota(0, 6)
             | views::filter(even)
             | std::views::transform(square))
             std::cout << i << ' ';
0 баллов
1 Решение
RabiyaSK_Intel
Сотрудник
2 047Просмотр.
Could you please try with latest oneAPI toolkit(2023.1 version)?
We didn't face any issues while executing your code on 2023.1 oneAPI toolkit. Please refer to the below screenshot.
If you still face any issues, you can reach out to us.
Thanks & Regards,
Shaik Rabiya
Просмотреть решение в исходном сообщении
3 Ответы
RabiyaSK_Intel
Сотрудник
2 048Просмотр.
Thanks & Regards,
Shaik Rabiya
MXG
Новый участник I
1 990Просмотр.
Installed version 2023.1.0 on Linux and it worked fine - thanks!
Morten
RabiyaSK_Intel
Сотрудник
1 963Просмотр.
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Shaik Rabiya
Ответить
