hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Skipping items in parallel_for()
leilag
초보자
4,600 조회수
In case I don't want to iterate all the items, is there an efficient way to break parallel_for()?
Leila
0 포인트
1 솔루션
Sravani_K_Intel
중재자
4,291 조회수
Hi Leila,
Compiler engineers confirmed that the warning was emitted by mistake and the loop is being successfully unrolled. The false warning issue is now fixed and you will no longer see it in the upcoming release of the compiler.
원본 게시물의 솔루션 보기
0 포인트
12 응답
VidyalathaB_Intel
중재자
4,577 조회수
Could you please let us know the Use Case on which you want to implement this >> way to break parallel_for()
and also the way which you are following currently in your code, for skipping some of the iterations ?
So that we can work on it from our end.
Thanks & Regards,
Vidya.
0 포인트
leilag
초보자
4,569 조회수
Hi Vidya,
This is my current code:
void init_velocity(queue q, const int m, const int n, double psi[DOMAIN_SIZE],
                                double u[DOMAIN_SIZE], double v[DOMAIN_SIZE], double p[DOMAIN_SIZE]) {
// DOMAIN_SIZE = (m+2)*(n+2)
auto R = range<1>{DOMAIN_SIZE};
buffer<double, 1> u_buf(u, R), v_buf(v, R), p_buf(p, R), psi_buf(psi, R);
q.submit([&](handler &h) {
     auto psi = psi_buf.get_access(h, read_only);
     auto u = u_buf.get_access(h, write_only);
     auto v = v_buf.get_access(h, write_only);
     auto p = p_buf.get_access(h, write_only);
     h.parallel_for(R, [=](auto ij) {
         int j = ij%(n+2);
         int i = (int) (ij - j)/(n+2);
        int ijm1 = ij-1;
        int im1j= ij-(n+2);
        if (i==0 || j==0 || i == m+1 || j== n+1) {}
       else {
       u[ij] = -(psi[ij] - psi[ijm1]) / dy;
       v[ij] = (psi[ij] - psi[im1j]) / dx;
      p[ij] = pcf * (cos(2. * (i-1) * di) + cos(2. * (j-1) * dj)) + 50000.;
To skip the exterior nodes, I have used `if (i==0 || j==0 || i == m+1 || j==n+1) {}`.  I might also care about some random interior nodes as well!
Please let me know if I need to explain more.
Leila
0 포인트
leilag
초보자
4,536 조회수
Any comments/thoughts?
0 포인트
VidyalathaB_Intel
중재자
4,519 조회수
Could you please give us some more details regarding the above statement, which might help us in sorting out the issue.
Vidya.
0 포인트
leilag
초보자
4,512 조회수
Thank you for getting back to me.
The following figure is an example of a physical problem which is similar to what I care to solve.
The exterior nodes (red and blue) are the ones that I want to skip. This is what I am trying to do in the code above. ie. is there a way to exclude some items in a parallel_for() operation?
Honestly, this is my main concern right now. I am wondering if there are other ways to do this with DPC++ or should I just make my peace with this naive approach.
A random interior node that I mentioned above could be something in the middle (is labeled by "Node m,n") that I might want to skip or treat it differently. But, if I can find an answer to my main question (skipping the exterior nodes), this should be easy to figure out.
Thank you for helping me with this and please let me know if I need to explain more.
Leila
0 포인트
leilag
초보자
4,505 조회수
Hi again,
Another example in C would be
for (int i=2; i<global_size-1; i++) {}
instead of
for (int i=0; i<global_size; i++) {}
ie. could we limit the scope of parallel_for() or even increase the stride?
Leila
0 포인트
VidyalathaB_Intel
중재자
4,460 조회수
Thanks for your patience.
We are looking into this issue internally. we will get back to you soon.
Vidya.
Sravani_K_Intel
중재자
4,370 조회수
Hi Leila,
The exterior nodes can be skipped by using 2 dimensional nd-range (https://www.khronos.org/registry/SYCL/specs/sycl-2020/html/sycl-2020.html#_nd_range_kernels) and adjusting the range accordingly. For random interior nodes, what you are doing might be the best possible option.
0 포인트
leilag
초보자
4,346 조회수
Hello Sravani,
Thanks for your answer!
I did try 2d range in the beginning which was ideally what I was hoping to do but there was a compiler warning which dissuaded me!
// 2D range
#include <vector>
#include <chrono>
#include <fstream>
#include <iostream>
#include <cmath>
#include "dpc_common.hpp"
#include <limits>
#include <CL/sycl.hpp>
#if FPGA || FPGA_EMULATOR
#include <CL/sycl/INTEL/fpga_extensions.hpp>
#endif
using namespace std;
using namespace sycl;
#define M 4
#define N 5
#define DOMAIN_SIZE (M+2)*(N+2)
int main () {
    //int dim = 2;
    auto R = range<2>{M+2, N+2};
    double u[DOMAIN_SIZE];
    buffer<double, 2> u_buf(u, R);
    for (int i=0;i<DOMAIN_SIZE; i++) u[i] = 0.;
    default_selector d_selector;
    queue q(d_selector);
        h.parallel_for(R, [=](auto index) {
            u[index[0]][index[1]] =  index[0] + index[1];
    host_accessor u_read(u_buf, read_only);
    for (int i=0; i<M+2; i++)
        for (int j=0; j<N+2; j++)
            std::cout << "u[" << i << "][" << j << "] = " << u_read[i][j] << std::endl;
    return(0);
And here is the warning:
In file included from t002.cpp:6:
In file included from /glob/development-tools/versions/oneapi/2021.2/inteloneapi/dev-utilities/2021.2.0/include/dpc_common.hpp:15:
In file included from /glob/development-tools/versions/oneapi/2021.2/inteloneapi/compiler/2021.2.0/linux/bin/../include/sycl/CL/sycl.hpp:11:
In file included from /glob/development-tools/versions/oneapi/2021.2/inteloneapi/compiler/2021.2.0/linux/bin/../include/sycl/CL/sycl/ONEAPI/atomic.hpp:11:
In file included from /glob/development-tools/versions/oneapi/2021.2/inteloneapi/compiler/2021.2.0/linux/bin/../include/sycl/CL/sycl/ONEAPI/atomic_accessor.hpp:14:
/glob/development-tools/versions/oneapi/2021.2/inteloneapi/compiler/2021.2.0/linux/bin/../include/sycl/CL/sycl/accessor.hpp:883:5: warning: loop not unrolled: the optimizer was unable to perform the requested transformation; the transformation might be disabled or specified as part of an unsupported transformation ordering [-Wpass-failed=transform-warning]
    for (int I = 0; I < AdjustedDim; ++I) {
1 warning generated.
Is there a reason why dpcpp cannot optimize a 1d array with a 2d range?
Thanks!
Leila
0 포인트
Sravani_K_Intel
중재자
4,298 조회수
Sorry for the delay in my response.
I tried this code with the latest internal compiler build and no longer see the warning. I am seeking clarification on this from the compiler team and will get back to you once I hear back.
0 포인트
Sravani_K_Intel
중재자
4,292 조회수
Hi Leila,
0 포인트
leilag
초보자
4,235 조회수
Hello Sravani,
Thanks for checking that for me.
Best,
Leila
0 포인트
응답
