Example of submatrix multiplication
pawan_k_
初學者
2,234 檢視
Are there any example of using dgemm for multiplying submatrices of two matrices?
Pawan
0 積分
5 回應
Sridevi_A_Intel
2,234 檢視
Pawan,
Can you look into the examples directory inside MKL Installation folder?
-Sridevi
pawan_k_
初學者
2,234 檢視
I looked into the example on dgemm. It is not quiet clear how to set lda etc for subblocks.
Here is an example I create.
A = [ 0  1  2   3   4   5   6   7   8   9
       10 11 12 13 14 15 16 17 18 19
        20 21 22 23 24 25 26 27 28 29
        30 31 32 33 34 35 36 37 38 39
        40 41 42 43 44 45 46 47 48 49
        50 51 52 53 54 55 56 57 58 59
B  =  [
         0  1  2  3  4  5
        6  7  8  9 10 11
        12 13 14 15 16 17
        18 19 20 21 22 23
         24 25 26 27 28 29
C  = [ 0  1  2   3   4   5  6   7
         8   9 10 11 12 13 14 15
         16 17 18 19 20 21 22 23
         24 25 26 27 28 29 30 31
All right! Now I want to operate on submatrices. Let us say I want to multiply a 4x3 submatrix of A as
follows
sub_matrix_A = [
                            14 15 16
                            24 25 26
                            34 35 36
                            44 45 46
with a 3x2 sub-matrix of B as follows
sub_matrix_B = [
                      7  8
                    13 14
                    19 20
to put in the 4x2 sub-matrix of C as follows
sub_matrix_C = [
          12 13
           20 21
          28 29
          36 37
Could someone work out this example for me and future MKL users ? Below are
the parameters to be filled.
cblas_dgemm(CblasRowMajor, CblasNoTrans, CblasNoTrans,
                m, n, k, alpha, A, k, B, n, beta, C, n);
I want to know the right values of m, n, k to perform
   sub_matrix_C = sub_matrix_A * sub_matrix_B
for the example above.
Pawan
pawan_k_
初學者
2,234 檢視
Could anyone workout this example?
Pawan
mecej4
榮譽貢獻者 III
2,234 檢視
I suggest that you perform this operation in two steps. Keeping in mind that CBLAS functions are wrappers around the underlying Fortran BLAS routines, and that terms such as "leading dimension" are confusing and possibly incorrect if the C convention of storing matrices as a 1-D array obtained from concatenation of the rows, examine the attached Fortran example and see if it does what you want.
After noting that the results are as expected, we can move on to replicating the same using C and CBLAS, as in the second attached file.
Ying_H_Intel
主席
2,234 檢視
Hi Pawan,
You can calculate the sub_matrix multiply by the below parameters
    double alpha = 1.0, beta = 0.;
    int m=4; int k=3; int n=2;
    int lda=10; // the stride of row
    int ldb=6;
    int ldc=8;
    double * subA=&A[0][0]+14;
    double * subB=&B[0][0]+7;
    double * subC=&C[0][0]+12;
I attached the cpp file for you reference.
Ying
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#include <mkl.h>
void init_arr(int N, double* a);
int main(int argc, char* argv[])
    double A[6][10];
    double B[5][6];
    double C[6][8];
    init_arr(60,&A[0][0]);
    init_arr(30,&B[0][0]);
    init_arr(48,&C[0][0]);
    int ldb=6;
    int ldc=8;
    cblas_dgemm(CblasRowMajor,CblasNoTrans,CblasNoTrans,m,n,k,alpha,subA,lda,subB,ldb,beta,subC,ldc);
    printf("Sub Matrix C(mxn): %d x %d\n", m, n);
    for (int i=0;i<m;i++){
    for (int j=0;j<2;j++) {
            printf("%g\t",subC[ldc*i+j]);
    printf("\n");}
    return 1;
    int i=0;
    for(i=0; i<N;i++)
            a = i;
build it with mkl library and get
The result is as below
Sub Matrix C(mxn): 4 x 2
597     642
987     1062
1377    1482
1767    1902
Press any key to continue . . .
回覆
