7234 Discussions
How to set up the environement of Intel MKL on MacOS?
Kai181216
Hi, I'm wondering how to apply the MKL into the system environment. Cuz I have already download and install the oneAPI,  but when I make the use of it, the terminal still said that the
Intel MKL does not seem to be installed. 5561623663543_.pic.jpg5571623663599_.pic_hd.jpg
ArpitaP_Intel
The environment needs to be sourced using the setvars.sh, to make it compatible for MKL to work fine.
You can follow the below link to achieve it.
https://software.intel.com/content/www/us/en/develop/documentation/oneapi-programming-guide/top/oneapi-development-environment-setup/use-the-setvars-script-with-linux-or-macos.html
Let us know, if issue persists.
Arpita
Kai181216
Thank you for your reply! I have already used setvars.sh , while I want to set up in my default environment, but I can't find the /etc/environment file. Is there any detail for the environment setting for MacOS?
ArpitaP_Intel
So, do you want to run your MKL executables on default environment, without sourcing the environment every time with setvars.sh ?
Arpita
Kai181216
Hi Arpita,
Yes, I want to set MKL as the default environment on my Macbook, so do you have any approach to guidance?
All the best
ArpitaP_Intel
Hi Kai,
You can include the oneAPI environment sourcing script in bashrc file. By doing this, every time your default environment gets sourced and you can use oneAPI MKL without running the script every time.
Arpita
Kai181216
I know how to solve it, many thanks!!
ArpitaP_Intel
Hi Kai,
Thanks for the confirmation. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Arpita
