Объявления
7234 Обсуждение
Intel MKL FATAL ERROR: Cannot load <mkl-loader>.
mwlai
Начинающий
5 247Просмотр.
Hello
I upgraded Numpy (1.16.6) and Pandas(1.1.5).
When I run python with django + apache + mod_wsgi , it fails with error: Intel MKL FATAL ERROR: Cannot load <mkl-loader>.
I've installed MKL( l_onemkl_p_2021.1.1.52_offline.sh ).
OS:
Red Hat Enterprise Linux Server release 7.4 (Maipo)
CPU:
Intel(R) Xeon(R) CPU E5-2660 v3 @ 2.60GHz
This is apache error log.
How can I fix this error? Thanks.
0 баллов
7 Ответы
mecej4
Почетный участник III
5 216Просмотр.
I suspect that this is related to an error in some Python component, rather than in MKL itself.
The text <mkl-loader> suggests that "mkl-loader" is just place-holder text -- that is what the surrounding angle-brackets usually signify. What is to be used as the substitution text?
Failing that, you may need to find the actual source line containing that text. If it is in an Intel-supplied file, you could provide the details here. Otherwise, the question may need to be asked in some Python support forum -- I do not know which.
mwlai
Начинающий
5 179Просмотр.
Thank you for your advice.
I did not find actual source line containing <mkl-loader>, and my python project log is empty.
It seems that python is loading some lib, but the error does not show which lib loaded fail, maybe it is numpy.
I rebuild numpy and scipy by intel document, as follow, but it not fix error.
https://software.intel.com/content/www/us/en/develop/articles/numpyscipy-with-intel-mkl.html
And attached file is what .bashrc set.
Is that CPU too old to use MKL?
Or is there wrong path in .bashrc?
mwlai
Начинающий
5 174Просмотр.
The Attached File as follow
AbhishekD_Intel
Модератор
5 205Просмотр.
We are forwarding this issue to the concerned team.
Warm Regards,
Abhishek
Gennady_F_Intel
Модератор
5 165Просмотр.
<< no, that's CPU type is pretty new and is supported by MKL, but
In general, I do believe you have to address this topic to Python Forum follow the link:
https://community.intel.com/t5/Intel-Distribution-for-Python/bd-p/distribution-python
Gennady_F_Intel
Модератор
5 150Просмотр.
the thread is closed and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Ответить
