MKL 2019U3 seems to load 32bit-DLL from 64bit-App
Dirks__Nils
Hello!
I'm porting a c++ application to x64. MSVS 2017 / C++ on Win7/64bit machine.
I've set project settings to generate code multithreaded / static linking.
However the spplication won't even start. It looks like the app is loading (and unloading) the 32bit libiomp5md.dll before it exits with code (0xc000007b).
How can I assure that the static 64bit-libs are linked and no other (possibly 32bit) DLLs get loaded?
thanks for any hints!
Gennady_F_Intel
How did you link your case? Check first the MKL libraries you linked with. It should be looks like as follows: mkl_intel_lp64.lib mkl_intel_thread.lib mkl_core.lib libiomp5md.lib
This is windows, therefore you may just put libiomp5md.dll  ( 64 bit) to the directory where your exe file is located.
