In the file that I am attaching, I am simply trying to compute the matrix multiplication A^T*A using the scalapack routine PDSYRK . Matrix A is randomly generated in row major order, and since scalapack uses column major order, I am calling pdsyrk_ in the non-transpose mode. The program works when A is a square matrix, but it calls MPI_Abort (error code -8) when I run it on non-square matrices.
What am I doing wrong?
Thanks for providing the source code and commands to reproduce the error.
We are able to reproduce the error which you are facing.
For Non-Square Matrix, use Transpose mode in the PDSYRK API call. We tried to run the code in Transpose mode and it is working.
Edit the below line in your code.
pdsyrk_("U", "T", &m, &n, &done, subA, &one, &one, descSubA, &dzero, subC, &one, &one, descSubC);
Let us know if you face any issues.
Goutham
連結已複製
Thanks for reaching out to us!
We have gone through the attached source code, could you please provide "matrices.h" and "common.h" source files.
Also, please provide steps to reproduce the error along with commands which you are using to compile the code.
Goutham
Here are the files that are included in the first code that I attached.
In this program, they are useful only for defining the "real" type (either double or float), but at the moment I am not managing yet the possibility of using floats, as I am evoking pdsyrk directly.
To compile, I use the following line:
mpiicc -std=c99 -O3 -qopenmp -DMKL_ILP64 -I${MKLROOT}/include BenchScalapack.c matrices.c -o main -L${MKLROOT}/lib/intel64 -mkl -lmkl_scalapack_ilp64 -lmkl_intel_ilp64 -lmkl_intel_thread -lmkl_core -lmkl_blacs_intelmpi_ilp64 -liomp5 -lpthread -lm -ldl -DDOUBLE_PRECISION
And to run:
mpirun -np 4 ./main 30 20
Matrix A in this case is 30x20 and I am getting the following error:
application called MPI_Abort(MPI_COMM_WORLD, -8) - process 0
application called MPI_Abort(MPI_COMM_WORLD, -8) - process 1
application called MPI_Abort(MPI_COMM_WORLD, -8) - process 2
application called MPI_Abort(MPI_COMM_WORLD, -8) - process 3
Thank you for your help!
Goutham
Thanks for the confirmation!
As this issue has been resolved, we will no longer respond to this thread.
If you require any additional assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only.
Have a Good day.
Thanks & Regards
Goutham
