error LNK2019: unresolved external symbol DGETRF_MKL95 referenced in function SUPORTBASE_mp_INVMAT
Radek_Z_
I inherited some project done in Fortran 95. After upgrade from Intel Fotran Composer v2013 to v2016, I am receiving errors during linking:
1>suportbase.obj : error LNK2019: unresolved external symbol DGETRF_MKL95 referenced in function SUPORTBASE_mp_INVMAT
1>suportbase.obj : error LNK2019: unresolved external symbol DGETRI_MKL95 referenced in function SUPORTBASE_mp_INVMAT
...fatal error LNK1120: 2 unresolved externals
The code which cause the problem:
pure function invmat(a) result(b)
USE usedlapck95_mod, ONLY: getrf,getri
USE, INTRINSIC :: IEEE_ARITHMETIC
implicit none
    real(8),intent(in),dimension(:,:) :: a
    real(8),dimension(size(a,1),size(a,1)) :: b
    integer(4),dimension(size(a,1)) :: ipiv
    integer(4) :: info
    b=a
    if (size(a,1)==0) return
    call getrf(b,ipiv,info)
    call getri(b,ipiv,info)
    if (info>0) b=IEEE_VALUE (b,IEEE_POSITIVE_INF)
end function
The code produce inverse matrix and it uses MKL library rutines.
The module which is called is:
MODULE F95_PRECISION
    INTEGER, PARAMETER :: SP = KIND(1.0E0)
    INTEGER, PARAMETER :: DP = KIND(1.0D0)
END MODULE F95_PRECISION
MODULE usedlapck95_mod
INTERFACE GETRF
    PURE SUBROUTINE SGETRF_MKL95(A,IPIV,INFO)
        ! MKL Fortran77 call:
        ! SGETRF(M,N,A,LDA,IPIV,INFO)
        USE F95_PRECISION, ONLY: WP => SP
        INTEGER, INTENT(OUT), OPTIONAL :: INFO
        REAL(WP), INTENT(INOUT) :: A(:,:)
        INTEGER, INTENT(OUT), OPTIONAL, TARGET :: IPIV(:)
    END SUBROUTINE SGETRF_MKL95
    PURE SUBROUTINE DGETRF_MKL95(A,IPIV,INFO)
        ! DGETRF(M,N,A,LDA,IPIV,INFO)
        USE F95_PRECISION, ONLY: WP => DP
    END SUBROUTINE DGETRF_MKL95
    PURE SUBROUTINE CGETRF_MKL95(A,IPIV,INFO)
        ! CGETRF(M,N,A,LDA,IPIV,INFO)
        COMPLEX(WP), INTENT(INOUT) :: A(:,:)
    END SUBROUTINE CGETRF_MKL95
    PURE SUBROUTINE ZGETRF_MKL95(A,IPIV,INFO)
        ! ZGETRF(M,N,A,LDA,IPIV,INFO)
    END SUBROUTINE ZGETRF_MKL95
END INTERFACE GETRF
INTERFACE GETRI
    PURE SUBROUTINE SGETRI_MKL95(A,IPIV,INFO)
        ! SGETRI(N,A,LDA,IPIV,WORK,LWORK,INFO)
        INTEGER, INTENT(IN) :: IPIV(:)
    END SUBROUTINE SGETRI_MKL95
    PURE SUBROUTINE DGETRI_MKL95(A,IPIV,INFO)
        ! DGETRI(N,A,LDA,IPIV,WORK,LWORK,INFO)
    END SUBROUTINE DGETRI_MKL95
    PURE SUBROUTINE CGETRI_MKL95(A,IPIV,INFO)
        ! CGETRI(N,A,LDA,IPIV,WORK,LWORK,INFO)
    END SUBROUTINE CGETRI_MKL95
    PURE SUBROUTINE ZGETRI_MKL95(A,IPIV,INFO)
        ! ZGETRI(N,A,LDA,IPIV,WORK,LWORK,INFO)
    END SUBROUTINE ZGETRI_MKL95
END INTERFACE GETRI
INTERFACE SYEVD
        ! JOBZ='N','V'; default: 'N'
        ! UPLO='U','L'; default: 'U'
    PURE SUBROUTINE SSYEVD_F95(A,W,JOBZ,UPLO,INFO)
        ! Fortran77 call:
        ! SSYEVD(JOBZ,UPLO,N,A,LDA,W,WORK,LWORK,IWORK,LIWORK,INFO)
        CHARACTER(LEN=1), INTENT(IN), OPTIONAL :: JOBZ
        CHARACTER(LEN=1), INTENT(IN), OPTIONAL :: UPLO
        REAL(WP), INTENT(OUT) :: W(:)
    END SUBROUTINE SSYEVD_F95
    PURE SUBROUTINE DSYEVD_F95(A,W,JOBZ,UPLO,INFO)
        ! Fortran77 call:
        ! DSYEVD(JOBZ,UPLO,N,A,LDA,W,WORK,LWORK,IWORK,LIWORK,INFO)
    END SUBROUTINE DSYEVD_F95
END INTERFACE SYEVD
end module
Does anybody has an idea how to fix the problem with linker? I have "light" experience with Fortran so far, my colleagues do but they don't have any idea too.
Thank!
mecej4
Some module and library names were changed in recent versions of MKL. What you need with IFort 16 is
      USE f95_precision, ONLY: WP => DP
      USE lapack95, ONLY: GETRF, GETRI
in the subprogram source from which GETRF and GETRI are called, and you need to add the appropriate Lapack95 library to the linker line. The library file to use is mkl_lapack95.lib for 32-bit targets, and mkl_lapack95_lp64.lib (if passing 4-byte integer arguments) or mkl_lapack95_ilp64.lib (if passing 8-byte integer arguments) for 64-bit targets.
There is no need to use your own module source (usedlapck95_mod).
Radek_Z_
Thank you! That solved my problem! :-)
