update MKL 2013.4.190 fails to install documentation in MS Help Viewer
snowman
After upgrade to Intel Visual Fortran Compser XE 2013.4, including MKL, for Windows (released on May 29),
no MKL documentation has been integrated in MSHelp 2.0, due apparently non-updated links (see image below)
SergeyKostrov
Valued Contributor II
Could you verify if mkl_userguide_11_0_3.cab file exists in some folder on your system?
snowman
Dear Sergey,
I have already solved the problem on my computer.
The problem was due to different version numbers in the file names:
1) in the file helpcontentsetup.msha references are given to the following files:
mklman_11_0_3.cab
2) presented are files:
mkl_userguide_11_0_4.cab with mklman_11_0_3.mshc inside, and
mklman_11_0_4.cab with mkl_userguide_11_0_3.mshc inside
So, my solution was just to rename mkl_userguide_11_0_4.cab -> mkl_userguide_11_0_3.cab, and
mklman_11_0_4.cab -> mklman_11_0_3.cab.
Then, the documentation can be added into the help system manually.
Best regards
Gennady_F_Intel
I don't see the problem. I installed 2013.4.190 on the clear system and all work as expected. Do you see the *.cab files into the Documentation directory?
Alexander_U_1
Dear Gennady, the problem exists, see above.
SergeyKostrov
>>I have already solved the problem on my computer. >> >>The problem was due to different version numbers in the file names: >> >>1) in the file helpcontentsetup.msha references are given to the following files: >>mkl_userguide_11_0_3.cab >>mklman_11_0_3.cab Thanks for the update and I think MKL Installer team needs to make a note about that issue.
