Dear Intel devs,
TBB is a wonderfull library, thank you for all your work. I am currently experimenting, features of the library, that I have never tested. The pipeline package. I am currently chaining series of functor that can be "fat" in ressource computation, and which are already parallelized with a tbb::parallel_for. From my knowledge, it is not an issue. The thread pool of the parallel for and the parallel_pipeline should be common.
So is it reasonable to make a filter with a nested tbb::parallel_for inside ?
Same question, for the tbb::graph_flow library (tbb::parallel_for into a node) ?
Thank you
++t
Yes, you can use any TBB parallel algorithms inside another TBB parallel algorithm. Typically, it makes sense when outer level parallelism is not enough to utilize the system but each parallel work part is big enough to be paralleled.
![](/skins/images/895D6060305DF45A57FACF854B5A8CD1/responsive_peak/images/icon_anonymous_message.png)
