Hello Intel!
I really need your help, i'm a bit worried about my DX58SO motherboard because the onboard speaker seems to be not working (no beep sound). No beep sound since the first time I used it until now. I updated the system bios (to this date) and still no sound. I'm thinking maybe the onboard speaker is busted or something. How will I know if the speaker itself is the problem or there's something really wrong.
Everything seems to be working fine, except for the beep sound whnever I power up my computer. I think its also important for this to work because it will help me in troubleshooting whenever I encounter a problem (like memory problem, power, etc)
Thanks!
OS: Windows 7 Ultimate
Motherboard: Intel Smackover DX58SO BIOS: SOX5810J.86A.4598.2009.1211.1321
Processor: QuadCore Intel Core i7 920, 2.66 Ghz SLBEJ Bloomfield DO Socket LGA 1366 Core 45nm
Memory: 2 x 2 GB DDR3 1333mhz
GPU: MSI GeForce 9800GT 1024mb
HDD: WD 10EADS-00M2BO ATA Device 1TB SATA 3Gb/s 32mb cache
Optical Drive: LG Internal / GH22 Super Multi DVD Rewriter
Power Supply: Gigabyte GE-C420N-C2 1x 20-24 pin motherboard connector 1x 4 pin motherboard connector 1x 6 pin graphics card connector 3x SATA connectors 3x peripheral connectors (chassis fans etc.) 1x small 4 pin connector (i also think this is for extra fans and such)
Casing: Gigabyte GZ-X2 incl. 420watts PSU & 1x120mm Rear Fan
Monitor: ACER 19" LCD V193w
Others: Additional Fan: 1x120mm & 1x80mm
![](/skins/images/895D6060305DF45A57FACF854B5A8CD1/responsive_peak/images/icon_anonymous_message.png)
