- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
I'm trying to get Intel Endpoint Management Assistant to work. I have successfully provisioned a device in ACM. But "CIRA Not Connected"
The devices I try to onboard, are WiFi Only devices, Latitude 7450, Latitude 7440 etc.
2025-08-06 16:04:08.5855|ERROR||9116|3|ApplyWirelessConfiguration - MeshManageabilityServer.code.AmtSetup.WirelessManager, EMAManageabilityServer, Version=1.14.3.0, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - [1] - Failed to apply wireless configuration : (**bleep**-**bleep**,197AAD03).
Exception Level(0):WSManFault.Code: a:Sender WSManFault.SubCode: e:UnsupportedFeature
StackTrace Level(0): at Intel.Manageability.WSManagement.DotNetWSManClient.WSManSendReceive(Header header, XmlElement[] bodyIn, XmlElement[]& bodyOut)
at Intel.Manageability.WSManagement.DotNetWSManClient.Invoke(Uri resourceUri, Uri actionUri, XmlElement request, IEnumerable`1 selectors)
at Intel.Manageability.Cim.Untyped.CimObject.Invoke(String methodName, CimKeys keys, CimParams input, CimParams& output)
at Intel.Manageability.Cim.Typed.CimBase.Invoke[TInput,TOutput](String methodName, TInput input, TOutput& output)
at Intel.Manageability.Cim.Typed.AMT_WiFiPortConfigurationService.AddWiFiSettings(CimReference inWiFiEndpoint, CIM_WiFiEndpointSettings inWiFiEndpointSettingsInput, CIM_IEEE8021xSettings inIEEE8021xSettingsInput, CimReference inClientCredential, CimReference inCACredential, CimReference& outWiFiEndpointSettings, CimReference& outIEEE8021xSettings)
at ManageabilityStack.AmtWireless.AddWirelessProfile(AmtWirelessProfile profile, CIM_IEEE8021xSettings _8021XSettings, List`1 installedCertsEPRs)
at MeshManageabilityServer.code.AmtSetup.WirelessManager.AddWiFiProfile(WiFiSetup setup)
at MeshManageabilityServer.code.AmtSetup.WirelessManager.AddWiFiProfiles(WiFiConnection wiFiConnection)
at MeshManageabilityServer.code.AmtSetup.WirelessManager.ApplyWirelessConfiguration(AMTProfile amtProfile)
AMT is enabled in BIOS
Thanks for helping
Link copiado
- « Anterior
- 1
- 2
- Próximo »
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello AlphaSeb,
Greetings!!
Thank you for sharing your observations along with the requested details.
For further assistance, we would like to offer a meeting on Tuesday at 4:00 PM German Time (which is 7:00 AM PST, one hour before our regular business hours) so that we can review the issue together and perform the necessary checks. Please let us know if this time works for you.
Vishal Shet P
intel.com/vpro
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
04:00PM on Tuesday doesn’t work for me. But it works any other day of the week.
Thank you!
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello AlphaSeb,
Greetings!!
Thank you for letting us know. We will check the availability for another day and get back to you with an updated schedule.
Vishal Shet P
intel.com/vpro
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Could you please send me an email with a proposed meeting time?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello AlphaSeb,
Greetings!!
We analyzed the logs and details you shared and found that we missed updating the new FQDN by reinstalling EMA after the domain name was changed from ema.alphatrains.eu to ema.alphatrains.com.
It is required to use the correct FQDN that matches the certificate purchased. Otherwise, issues may occur. Please refer to the link below in the Intel EMA Server Installation Guide, section 2.2.1.3 Load Balancer Information, which shows the screenshot where you need to update the latest FQDN from ema.alphatrains.eu to ema.alphatrains.com.
Once this is done, please disable the option Enable WiFi profile sharing with UEFI BIOS, as this option may cause additional issues.
If the issue continues, please let us know your availability on Tuesday, Aug 26th.
Vishal Shet P
intel.com/vpro
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello AlphaSeb,
Greetings!!
Thank you for providing the update.
We kindly request you to try accessing the AMT Web UI via https://localhost:16993 and log in using your username and password. I have also attached a screenshot of the AMT Web UI WiFi settings, showing how to Enable in S0, Sx/AC. After enabling, we request you to restart the endpoints.
If the issue persists after this, we request you to share the latest ECT logs with us so we can further investigate.
Intel® EMA Configuration Tool (ECT) Logs:
- Download the tool from the following link: Intel® EMA Configuration Tool
- Installation:
- Download and unzip the tool.
- Double-click the .msi file and follow the installation prompts.
- Run the Tool:
- a. Open a command prompt as an administrator (or use Windows PowerShell*).
- b. Navigate to the installation folder (default: C:\Program Files (x86)\Intel\EMAConfigTool).
- c. Run the following command:
- EMAConfigTool.exe --verbose
Please let us know your findings.
Vishal Shet P
intel.com/vpro
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Hello AlphaSeb,
Greetings!!
We are following up on our previous email in which we provided the plan of action to be performed. Kindly let us know if you were able to proceed with the suggested steps or if you need any further assistance from our side.
Vishal Shet P
intel.com/vpro
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Wifi, is enabled (it was always enabled like that)
I deployed a new SSID (AlphaTrains-Corporate-Mobile) and for some reason it's connected now to CIRA.
However, only In-Band. Out of band, it's loosing connection. So we are back at this issue now. See next post for EmaConfigTool Logs.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello AlphaSeb,
Greetings!!
As mentioned, we can see that the In-Band connection is showing as connected, and the logs you shared are reflecting the same. We kindly request you to connect the power cables to the Out-of-Band interface, as it was losing connection earlier.
Once this is done, please share the updated logs with us so we can review them further.
Vishal Shet P
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Dear Vishal,
What do you mean?
This is a Dell Latitude 7440 Laptop, and it is and was always connected to AC/Power during the tests?!
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
In Band:
Out of Band:
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi AlphaSeb,
If CIRA over WiFi is connecting with OS is working but not connecting with OS in not working, it is likely either the WiFi profile used in the Intel AMT profile is not configured correctly (e.g. TKIP vs CCMP), or there is 802.1x network authentication on your WiFi network but your WiFi profile on Intel EMA is not configured to use 802.1x.
Jimmy Wai
Technical Sales Specialist, Intel
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Jimmy,
I can confirm that the WiFi Profile is configured correctly (WPA2 CCMP)
And thats what we are using in the company. We no longer use WPA2-Enterprise 802.1.x.
I tried with UEFI BIOS sharing, and without. No difference..
I wonder if the Dell Laptops even support OOB or if theres some BIOS Setting preventing this?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi AlphaSeb,
If you are not using UEFI WiFi, I would recommend turn that option off in Intel AMT profile. Have you try connecting the PC to a mobile phone WiFi hotspot or home WiFi? Does CIRA connects OOB in that scenario?
Jimmy Wai
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello AlphaSeb,
Greetings!!
We have sent you an email requesting a web meeting. Kindly confirm if you have received it and let us know your preferred option, so that we can assist you accordingly.
Pujeeth
IntelvPro.com
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
- « Anterior
- 1
- 2
- Próximo »
