Intel vPro® Platform
3049 Discussions
Error of HPOV
Any expert can give me support.
I can find the amt machine in LAN,but we can't control the client.
ISV: HPOV
attached is error log, fyi.
Service Logs
Date
Description
Severity
Originator
UUID
AMT FQDN
Originator Server
Message ID
Request ID
2/27/2008 5:45
Set rng key on Intel AMT device.
Information
VPRODEMO\SCSServiceAccount
C9796B3F-A955-11DC-BBDA-FE9DD0CD000F
amt-7800.vprodemo.com
HPOPENVIEW
1342113344
9762
2/27/2008 5:45
Exception in set rng key worker: (0xCFFF06AC) SOAP Failure (22): setRngKey: Http error.
Error
HPOPENVIEW
3489596283
9762
2/27/2008 5:45
Exception when trying to push request - 0xCFFF0089 : Another process is currently working on Intel AMT device..
Error
HPOPENVIEW
3489596144
9761
2/27/2008 5:45
Exception when processing Maintenance worker - 0xCFFF0089 : Another process is currently working on Intel AMT device."
Error
HPOPENVIEW
3489596167
9761
2/27/2008 5:40
Information
HPOPENVIEW
1342113344
9758
2/27/2008 5:40
Error
HPOPENVIEW
3489596283
9758
2/27/2008 5:40
Error
HPOPENVIEW
3489596144
9757
2/27/2008 5:40
Error
HPOPENVIEW
3489596167
9757
2/27/2008 5:35
Information
HPOPENVIEW
1342113344
9754
2/27/2008 5:35
Error
HPOPENVIEW
3489596283
9754
2/27/2008 5:35
Error
HPOPENVIEW
3489596144
9753
2/27/2008 5:35
Error
HPOPENVIEW
3489596167
9753
2/27/2008 5:30
Error
HPOPENVIEW
3489596283
9750
2/27/2008 5:30
Information
Brian_Cockrell
The last line in your error log states "Cannot contact provisoned Intel AMT device at FQDN - amt-7800.vprodemo.com." Your DNS may not be resolving the client by FQDN. Try pinging your client by FQDN and if it fails, flush the DNS cache and then try pinging it by FQDN again. Then refresh your HPOV window to determine if this resolves your issue.
about FQDN has fixed, thanks for your reply. and now we met the SOAP issue......
Brian_Cockrell
Do you have a screen shot or text of the soap error you are encountering?
When does the soap error occur?
I export the log file , SOAP error is following, pls refer to it.
This error not reproduce every time, about 4/5 reproduce.
3/4/2008 5:47
SOAP Failure (1): setPowerOptions: PT_STATUS_INTERNAL_ERROR: An internal error in the Intel(R) AMT device has occurred.
Error
B9BAE87A-92C0-11DC-1A98-66990E45C129
HPOPENVIEW
3489597100
12049
3/4/2008 5:47
Set power policies.
Information
cpro01.vprodemo.com
HPOPENVIEW
1342113355
12049
3/4/2008 5:47
Set ACL.
Information
HPOPENVIEW
1342113354
12049
3/4/2008 5:47
Successfully removed existing 802.1x wired profile.
Information
cpro01.vprodemo.com
HPOPENVIEW
1342112755
12049
3/4/2008 5:47
Remove existing 802.1x wired profile.
Information
cpro01.vprodemo.com
HPOPENVIEW
1342112754
12049
3/4/2008 5:47
Successfully set wireless profile ProDemoAP.
Information
cpro01.vprodemo.com
HPOPENVIEW
1342112744
12049
3/4/2008 5:47
Setting wireless profiles...
Information
cpro01.vprodemo.com
HPOPENVIEW
1342112724
12049
3/4/2008 5:47
Set enabled interfaces.
Information
cpro01.vprodemo.com
HPOPENVIEW
1342113352
12049
3/4/2008 5:47
Set TLS options.
Information
cpro01.vprodemo.com
HPOPENVIEW
1342113349
12049
3/4/2008 5:47
Set Ping Response.
Information
cpro01.vprodemo.com
HPOPENVIEW
1342112602
12049
3/4/2008 5:47
Set the host name to cpro01.
Information
cpro01.vprodemo.com
HPOPENVIEW
1342112600
12049
3/4/2008 5:47
Set domain name to vprodemo.com.
Information
cpro01.vprodemo.com
HPOPENVIEW
1342112599
12049
3/4/2008 5:47
Synchronize clock on Intel AMT device.
Information
cpro01.vprodemo.com
HPOPENVIEW
1342113345
12049
3/4/2008 5:47
Information
cpro01.vprodemo.com
HPOPENVIEW
1342113344
12049
<td...
