- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
[Filter: smut] evenlin1's post body matched "xxx", board "vpro-platform".
Post Subject: Client cannot provision via EMA server
Post Body:
i try to provision client via EMA but encounter a problem as below
setup status show pending activation
i have add Suffix and FQDN in MEBX but still notwork...
attached the log from EMAConfigtool
PS C:\Program Files (x86)\Intel\EMAConfigTool> .\EMAConfigTool.exe
Issue with WSMAN connection: Unable to connect
Intel EMA Configuration Tool
Application Version: 1.1.0.183
*** Host Computer Information ***
Computer Name: XXXX-XXXXXX
Manufacturer: XXXXX
Model: XXXXXX
Processor: Intel(R) Core(TM) Ultra 5 245HX
Windows Version: Microsoft Windows 11 Pro
BIOS Version: XXXXXX (0.15 )
UUID: XXXX-XXX-XXXX-XXXX-XXXXXXX
*** ME Information ***
Version: 19.0.5.1992
SKU: Intel(R) Full AMT Manageability
State: Not Provisioned
Control Mode: None
Driver Installed: True
Driver Version: 2512.7.3.0
PKI DNS Suffix: local.com
LMS State: Running
*** ME Capabilities ***
AMT in Enterprise Mode: True
TLS Enabled: False
HW Crypto Enabled: True
Current Provisioning state: PRE_PROVISIONING_STATE
NetworkInterface Enabled: True
SOL Enabled: True
IDER Enabled: True
FWUpdate Enabled: False
LinkIsUp state: True
KVM Enabled: False
An error occurred.
Unhandled Exception: System.NullReferenceException: Object reference not set to an instance of an object.
at AshCreek.Program.WriteToConsole(Boolean writeVerbose)
at AshCreek.Program.Main(String[] args)
Body text "XXX" matched filter pattern "xxx".
Post by User[id=207157,login=evenlin1] was rejected for the following end-user facing error(s):
- The message body contains Crypto, which is not permitted in this community. Please remove this content before sending your post.
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello evenlin1,
Thank you for reaching out.
We’d like to inform you that we will be continuing our response in a different thread to keep the discussion organized. You can follow the conversation at the link below:
https://community.intel.com/t5/Intel-vPro-Platform/EMA-CIRA-connect-fail/m-p/1698335#M12973
Please feel free to reply there if you have any further questions or updates.
Vijay N
Intel Customer Support
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
