Intel vPro® Platform
3045 ディスカッション
I'm Having Problem with Intel DG33FB motherboard as i was unable to hear the sound from machine... Intel Core 2 Duo 2.66 GHz, Intel DG33FB Motherboard , 2Gb RAM, WIN XP SP2 Pro OS..... I tried WIN XP x64 OS But again failed .... I tried al trouble shoots
従業員
1,447件の閲覧回数
I tried all trouble shoots and also installed all apllications
but failed
PLEASE TELL ME SOLUTION.....
0 件の賞賛
1 返信
従業員
607件の閲覧回数
Hi there,
First thing that i will do is to update the BIOS to the latest one, using Recovery Mode.
Please read the read me file how to do it.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=2781&DwnldID=17260&strOSs=38&OSFullName=OSIndependent&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=2781&DwnldID=17260&strOSs=38&OSFullName=OSIndependent&lang=eng
Make sure that the Audio is enabled in the BIOS.
Then i will install the OS fresh.
If you are using Windows XP SP2, then after OS installation install these drivers in the following order.
1. Chipset
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProductID=2781&DwnldID=10884&strOSs=44&OSFullName=WindowsXPProfessional&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProductID=2781&DwnldID=10884&strOSs=44&OSFullName=WindowsXPProfessional&lang=eng
2. Sound
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=2781&DwnldID=16998&strOSs=44&OSFullName=Windows http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=2781&DwnldID=16998&strOSs=44&OSFullName=Windows*XPProfessional&lang=eng
3. Graphics
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProductID=2781&DwnldID=16954&strOSs=44&OSFullName=Windows http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProductID=2781&DwnldID=16954&strOSs=44&OSFullName=Windows*XPProfessional&lang=eng
4. Lan
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=2781&DwnldID=13478&strOSs=44&OSFullName=Windows http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=2781&DwnldID=13478&strOSs=44&OSFullName=Windows*XPProfessional&lang=eng
5. ME
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProductID=2781&DwnldID=13477&strOSs=44&OSFullName=Windows http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProductID=2781&DwnldID=13477&strOSs=44&OSFullName=Windows*XPProfessional&lang=eng
Other than this i dont have any suggestions.
Hope this helps.
Aryan
返信
