Intel vPro® Platform
3059 Discussions
IDE setup completed, but can't run Blink program
YChan26
Dear Expert,
I'm beginner for Galileo Board. I follow the "Intel Galileo Board Getting Start Guide" step by step. install the IDE at my windows 8 (64bit) and it success. I can see the "Galileo (COM4)" at Device Manager -> Ports (COM & LPT). I skip the step 6 ( update your board firmward) as my local support inform me not required, because the deliver board already update with latest firmware (IOT DEVELOPMENT KIT), as I run the terminal program as show in below.
I continue with step 7: "Open the blink example", until step 10, " upload the program" but I can see the "Done upload" message at the Arduino screen. May I know what wrong on my setup? hope expert can give some guide. See the message from the Arduino screen below:
===================== PART OF TERMINAL PROGRAM LISTING=====================================
Starting OpenBSD Secure Shell server: sshd
[ 31.850515] NET: Registered protocol family 10
[ 31.936541] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
done.
Starting Distributed Compiler Daemon: distcc.
Starting syslogd/klogd: done
* Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon [fail]
Starting Telephony daemon
Starting Lighttpd Web Server: lighttpd.
date: invalid date ''
[ 43.428396] g_serial gadget: high-speed config # 1: CDC ACM config
info: Forever processing file: agent.js
Starting OProfileUI server
Stopping Bootlog daemon: bootlogd.
** (oprofile-server:990): WARNING **: Failed to create avahi client: Daemon not running
Starting tcf-agent: OK
iot-devkit (Intel IoT Development Kit) 1.0 clanton /dev/ttyS1
clanton login: [ 959.203023] g_serial gadget: high-speed config # 1: CDC ACM con fig
clanton login:
=========================== End of terminal listing =============================================
========================== Listing from Arduino 1.5.3 ==========================================
Binary sketch size: 49,066 bytes (of a 262,144 byte maximum) - 18% used
cygwin warning:
MS-DOS style path detected: C:\arduino-1.5.3/hardware/arduino/x86/tools/izmir/clupload_win.sh
Preferred POSIX equivalent is: /cygdrive/c/arduino-1.5.3/hardware/arduino/x86/tools/izmir/clupload_win.sh
CYGWIN environment variable option "nodosfilewarning" turns off this warning.
starting download script
Consult the user's guide for more details about POSIX paths:
Args to shell: C:\arduino-1.5.3/hardware/tools/x86/bin C:\Users\user\AppData\Local\Temp\build4113998651985686361.tmp/Blink.cpp.elf COM4
http://cygwin.com/cygwin-ug-net/using.html# using-pathnames http://cygwin.com/cygwin-ug-net/using.html# using-pathnames
COM PORT 4
# !/bin/sh
Converted COM Port COM4 to tty port /dev/ttyS3
Sending Command String to move to download if not already in download mode
echo "starting download script"
echo "Args to shell:" $*
# ARG 1: Path to lsz executable.
# ARG 2: Elf File to download
# ARG 3: COM port to use.
# path contains \ need to change all to /
path_to_exe=$1
fixed_path=${path_to_exe//\\/\/}
# COM ports are not always setup to be addressed via COM for redirect.
# /dev/ttySx are present. Howwever, COMy -> /dev/ttySx where x = y - 1
com_port_arg=$3
com_port_id=${com_port_arg/COM/}
echo "COM PORT" $com_port_id
tty_port_id=/dev/ttyS$((com_port_id-1))
echo "Converted COM Port" $com_port_arg "to tty port" $tty_port_id
echo "Sending Command String to move to download if not already in download mode"
echo "~sketch download" > $tty_port_id
============================================ End of Listing ==================================
