We are in the process of cutting over from AD Authentication to Azure AD authentication on our Intel EMA 1.9.0.0 platform and I was wondering how (can) this is done, if the 1.9.0.0 install has already been performed in AD authentication mode?
It's OK, I think I found it in the 1.9.0.0 installation documentation; Section '2.4.4 Converting to Azure AD using the Command Line'.
Hello neilbrin,
We are glad to know that you've found a solution in our documentation. Since the thread is now solved, we will proceed to close it.
Victor G.
Topic Options
